Seamless walk cycle in ICLONE 7
Posted By karl.trolenberg 8 Years Ago
karl.trolenberg
karl.trolenberg
Senior Member (454 reputation)Senior Member (454 reputation)Senior Member (454 reputation)Senior Member (454 reputation)Senior Member (454 reputation)Senior Member (454 reputation)Senior Member (454 reputation)Senior Member (454 reputation)Senior Member (454 reputation)
Last Active: 7 Years Ago
Posts: 10, Visits: 49
I have a character with a puppet clip of him walking made in motion puppet. I want to make a seamless walk cycle out of this clip, but the beginning and end of the clip don't quite match up. What is the best way to fix this?
Keith_MPS
Keith_MPS
Posts: 385, Visits: 1.3K
The normal way to loop a clip is clicking the loop button and then dragging the end of the clip (in the timeline) to whatever length you like:
http://manual.reallusion.com/iClone_7/ENU/Pro/Default.htm#iClone_7/Pro_7.0/09_Animation_Timeline_Editing/Speed_Loop_and_Blending.htm
If that is what you're already doing, then you can try blending two identical clips (same page of the manual). You can try tweaking the length of the blending section of the following clip (drag the front of the clip to make the blend section shorter/longer). And you can also try with varying distances of when the new clip starts. It doesn't have to be directly against the previous clip...but the blend section should be against or overlapping the previous clip.
You can also try breaking the clip.  If you find the exact point where the clip will loop without any weirdness, right-click on the clip (on the timeline) and select Break. It will break the clip into two clips. You can delete the second part and try looping the first part (if you cut in the right spot).
- Keith
karl.trolenberg
karl.trolenberg
I'll try that. Thanks
