Hi,
CrazyTalk6 Web Avatar can only export Flash components. You need to utilize CrazyTalk to export this flash components first, and then you have to use WidGetCast and click on “Insert Flash” button to import this flash and its components. Finally, you can export the and upload the files to your web hosting.
Besides, if you use the common project (Not WebAvatar), you can utilize Output/Web tab to do web export. When you output FLASH file for the web , you should get .flv, AC_RunActiveContent.js, FlashSwf.swf in a folder. You have to convert the FLV format to SWF format via third-party software such as 4U FLV Converter and so on. Then, you must insert this SWF file into your webpage via webpage editor such as Dreamweaver and so on.
If you want to stop the FLASH looping, you have to add several HTML codes: <param name="LOOP" value="false"> and loop="false in <object>.
e.g. <object classid="clsid27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0" width="320" height="240">
<param name="movie" value="da/001.swf">
<param name="quality" value="high"><param name="LOOP" value="false">
<embed src="da/001.swf" width="320" height="240" loop="false" quality="high" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash"></embed>
</object>
Yours sincerely,
Mick
Technical Support
Reallusion Inc.
