Posts: 15.8K,
Visits: 31.4K
I have a project with a plane with a displacement map simulating a snowy surface. When moving the camera in Preview the surface wobbles as shown in the clip. It's OK in Final render (not in Preview render). This did not occur in 7.02.
It seems something specific to this project; I can't reproduce it with just a plane in a new project. This is an older iClone 6 project that I'm revamping. On several occasions I have had problems with projects from previous versions of iClone. BTW, as you can imagine, this makes it hard to adjust the plane's vertical position.
Posts: 15.8K,
Visits: 31.4K
Although restore was fixed in 7.02, I got a Restore failed message in iClone 7.1. This was after a power problem, but still. Anyone else having problems with restore?
Jfrog
Visits: 4.7K
I had the same problem with a displacement map floor (egypte temple). This happened only when trying to duplicate the floor to make it longer. I wasn't able to solve the problem so I had to erase the duplicated floor and forget about making it bigger. Another problem is the "look at" feature is even buggier than before even with correct key framing. Today I lost several hours trying to work around with the bugs. This is not encouraging at all. I think I will go back to 7.02.
Posts: 5.3K,
Visits: 16.8K
It crashed on me couple of times already while I was working with timeline keys. But both times automated restore worked fine.
Posts: 15.8K,
Visits: 31.4K
4u2ges (11/18/2017) It crashed on me couple of times already while I was working with timeline keys. But both times automated restore worked fine.
Thanks for the conformation. I had a power failure, so that is not a typical scenario.
Posts: 15.8K,
Visits: 31.4K
As a follow up to my displacement issue, I have now entered it in FT (issue #3648). I was able to reproduce the problem using a simple scene, consisting of a plane sized to 900% with a displacement map. The displacement map is a noise image, tiled 10 times. Other settings: Tessellation Level and Multiplier 10.
In the scene, the plane is rotated, which then results in "wobbling" in Preview. This is also present when rendering in Preview, but not in Final render. Here is the Preview render:
My GPU is a GTX 1080 with driver 385.41. (Newer drivers gave problems in 7.02.)
animagic (11/18/2017) As a follow up to my displacement issue, I have now entered it in FT (issue 3648).
How many times have people asked about animating ocean waves? Eureka! LOL
Posts: 5.3K,
Visits: 16.8K
I just noticed a "World Rotate" was added to bones. You guys were what much close to adding "Local Move"... but you have not. What a pity! :Whistling:
Colonel_Klink
Colonel_Klink
Last Active: 5 Months Ago
Posts: 1.1K,
Visits: 7.7K
Trying unsuccessfully to edit characters in CC2 using "Edit in Character Creator" from within iClone. It appears that CC is not getting the complete message as the icon on the task bar flashes but CC doesn't load the model. It worked fine through iClone 7.02.
* * * * * * * * * * * * * * * * * * See all my content in one place
 Facebook Page: CWK3D Game and Film Content Cancer Survivor - Retired Teacher - Geriatric Icloner still learning Hardware: ZX80; Operating System- ZX80 Basic; CPU - ZX80 @ 3.25 MHz; Memory - 1KB; Hard Drive - N/A; Storage - Cassette; Monitor: Any old CRT TV
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Trying unsuccessfully to edit characters in CC2 using "Edit in Character Creator" from within iClone. So it works for me. I tried different CC avatars Greets from Germany Postfrosch
