I have this same problem @ 21%
Testing with a default CC, imported into Akeytsu Version 1.0.1 (out of beta)
then as an unmodified Character saved back to FBX and tried to import into CC with the Key.. crashes.
I've also tried importing into Maya 2014 which throws the following errors:
2017-11-16 07:45:07: : Import: F:/Ascension Series 3D Models/ArmsWide/For Zbrush/FBX to Maya/Character_blank.fbx
2017-11-16 07:45:17: : [WARNING] BindPose - Incomplete BindPose [nodes parents] - The following parent and/or ancestor node(s) is/are not part of the BindPose definition. CC_Base_Hip CC_Base_R_Thigh CC_Base_L_Thigh CC_Base_R_Ribs CC_Base_L_Ribs CC_Base_FacialBone CC_Base_R_Calf CC_Base_R_ToeBase CC_Base_R_Forearm CC_Base_R_Upperarm CC_Base_L_Calf CC_Base_L_ToeBase CC_Base_L_Forearm CC_Base_L_Upperarm CC_Base_L_EyeRoot CC_Base_R_EyeRoot
2017-11-16 07:45:17: : [WARNING] BindPose - Incomplete BindPose [link nodes] - The following Link node(s) is/are not part of the BindPose definition. CC_Base_Teeth01 CC_Base_Teeth02
2017-11-16 07:45:17: : [WARNING] BindPose - Incomplete BindPose [link nodes parents] - The following parent and/or ancestor node of the Link(s) is/are not part of the BindPose definition. CC_Base_UpperJaw CC_Base_FacialBone CC_Base_Head CC_Base_NeckTwist02 CC_Base_NeckTwist01 CC_Base_Spine02 CC_Base_Spine01 CC_Base_Waist CC_Base_Hip CC_Base_BoneRoot CC_Base_JawRoot
2017-11-16 07:45:17: : [WARNING] Skin Definition - The imported scene has no initial binding position (Bind Pose) for the skin.
The plug-in will compute one automatically. However, running the 'Go To Bind Pose' command
may create unexpected results.
Store Page Link
76% of original size (was 659x19) - Click to enlarge
AMD 4.5 GHz 16 Cores | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
