I think in that case I used the animated version of Pudge for conversion:
In principle, the weapons are always connected to the meshbones (left), and as soon as you activate the animation (right):
they are adjusted to the mesh (hands etc.).
You can either use the Opacity slider in iClone:
or use another program (that keeps the bone structure) to remove them:
In order to get the weapons, you simply need to export them as "selected object" from (and then re-import to) 3DXChange:
and attach it to your hero in iClone.
There is really not much you can do wrong or that you should be afraid of !
;)Good luck !
