How to solve problems Iclone?
Posted By mort3z437 7 Years Ago
mort3z437
mort3z437
Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)Veteran Member (941 reputation)
Last Active: 7 Years Ago
Posts: 15, Visits: 29
3 bugs iclone. 1.skin flashing bugs. 2.Hand rigs problems . 3.Coming down the quality of the model
https://youtu.be/xsJFg92Xnbs
did you see
How do I solve problems
Last Active: 2 seconds ago
Posts: 8.1K, Visits: 60.5K
I would recommend that you do not use the sub-d in your DAZ exports. It is adding a rediculous amount of extra polys. If you want to make sure the mesh appears smooth, check the box in the iClone modify panel for "Realtime Smooth". It does the same thing sub-d does, but iClone friendly. Smile
To take care of the arms being rotated inside the body, raise them up in 3DXchange so that the character is in a Y-pose instead of a T-pose. For a quick workaround, and to help understand the problem, you can rotate the arms up in iClone using the Edit Motion Layer rotate gizmo.
