Custom eyebrows?
Posted By Jenova 9 Years Ago
Jenova
Jenova
Veteran Member (519 reputation)Veteran Member (519 reputation)Veteran Member (519 reputation)Veteran Member (519 reputation)Veteran Member (519 reputation)Veteran Member (519 reputation)Veteran Member (519 reputation)Veteran Member (519 reputation)Veteran Member (519 reputation)
Posts: 12, Visits: 417
Hello all, so in CC1 I was able to set eyebrows to 'input' and proceed to use a custom eyebrow RGB map, but in CC2 I can't find a way to remove the stock eyebrow, I select 'none' but the stock eyebrow is still visible, even when I select input and load my custom RGB map I can still see the stock eyebrow underneath it, is this a bug or am I doing something wrong?
Thanks in advance for any help, cheers guys.
https://forum.reallusion.com/uploads/images/ba5762c7-8028-4bb6-8a08-bd4c.png
https://forum.reallusion.com/uploads/images/79433ec1-e54a-4ae7-9573-b279.png
Last Active: 28 minutes ago
Posts: 8.2K, Visits: 62.6K
Looks like you've found bug to me!
But there is an easy fix. Before launching the Appearance Editor, make sure you select the PBR Substance for the head, body, etc. That one is a better one to use for iClone 7, and it will also work fine if you're exporting to iClone 6.
https://forum.reallusion.com/uploads/images/595c4407-591e-43bd-8c09-4cf7.jpg
https://forum.reallusion.com/uploads/images/e27ff2ff-427c-426b-a5df-60a4.jpg
Jenova
Jenova
Thanks for the help, Rampa, I'll submit a bug report to the tracker and use your work-around for now, thanks man. :)
