CritterJ
CritterJ
Last Active: 9 Months Ago
Visits: 50
Maybe it is becasue i am new to IC7 but my content is not showing up, For instance, my UN pack is not showing up, or the Professional Pack (Cop specifically) wont show up when i follow the paths to find them. Below is where i have been looking and it says, "not installed" for the cop parts, and for the UN stuff is just isn't there, any of it. Any advice?
Visits: 22.1K
I'm not going to download an image (you can just embed it next time so we can just see it here in the forum) but where, exactly, are you looking and what are you looking for? If you go to Props (the trees and triangle tab) and then to "PlaySet - UN Task Force" do you not have that folder? If you do, then there are things there. There is also a Playset - UN Task Force Bonus if you bought and want the Humvee. You will also have avatars in the Avatar tab (the one that looks like a person's head) under, again, Playset - UN Task Force. I don't know what "Professional" pack you're talking about (and I have everything RL sells). There is CC professional clothing, but that wouldn't be in iClone.
Last Active: 5 days ago
Posts: 15.8K,
Visits: 31.4K
CritterJ: Don't look under Packs, it's confusing. Look in the areas that Kelley indicates.
CritterJ
CritterJ
Visits: 50
All i get is this, i can click on the TaskForce and all that but no content shows up. i think i am still doing something wrong. Did i attach that correctly this time? i am not sure if i did it correctly. Also, i meant to put the Occupations-career, Law Enforcement. My bad
Visits: 22.1K
Let's go through this a bit at a time. First of all, your window is too small to display anything. If you look to the right of that window (where all the tabs like Content and Scene are) right opposite the UN Playset you'll see a row of vertical dots -- I do NOT mean the dots right next to the UN Playset, but WAY over to the right, where those side tabes like Content are. Move your mouse over to that and you'll be able to drag that window right to expand it. Something tells me that that is your entire problem (that your window is just too small to see the items once you've selected the folder). If you don't understand this, let me know and I'll post a video showing what I mean.
CritterJ
CritterJ
Visits: 50
SCORE! Thanks! i never would have figured that out on my own. Were there weapons in that pack as well?
Visits: 22.1K
There are weapons, and IIRC they are a bit hard to find. Let me look quickly... Ah, yes, they are located under Packs (so the first time you were close) and in Accessories in that UN playset. Have NO idea why they are organized that way. This is one of my pet peeves about how content is organized in iClone (and why I'm going to completely reorganize mine). I can never find things and although you can use the search function it won't search across categories. Now you should note you can also use Windows explorer -- turn on the icons view and you can see the props and things there, and then just drag them over into iClone. A lot of times this is FAR easier than doing it inside of iClone (and faster if you have as much content as I have).
