Does iClone 7 have any easy way to deal with pokethrough?
Posted By Inkubo 8 Years Ago
Inkubo
Inkubo
Senior Member (488 reputation)Senior Member (488 reputation)Senior Member (488 reputation)Senior Member (488 reputation)Senior Member (488 reputation)Senior Member (488 reputation)Senior Member (488 reputation)Senior Member (488 reputation)Senior Member (488 reputation)
Posts: 19, Visits: 81
My current understanding is that while DAZ characters can be imported as Nonstandard characters in iClone, there is no way to convert them into CC characters with clothing layers. So they cannot really "wear" clothes the same way native iClone characters can do.
For this reason, to clothe them one must put the clothes onto the character in DAZ and export the dressed character. Exporting the clothing separately from DAZ would do no good.
Here is a guy I exported, wearing a chest-plate with leather straps. In DAZ and 3DXchange, there is no poke-through, but of course as soon as he's loaded into iClone, his chest pokes through the leather shield near his underarm on his left, and the straps over his right chest disappear into his body.
Does the new iClone have any better method for curing this than fooling with the opacity map? On straps like these, it would be difficult to get the opacity map right, and then even if I did, when he moved to a different position, the hole in his skin would probably be exposed.
What options do I have for dealing with this, other hand discarding this item of clothing?
https://forum.reallusion.com/uploads/images/a021070c-88d2-49ed-b3d2-305b.png
Bellatrix
Bellatrix
Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)Distinguished Member (3.6K reputation)
Posts: 420, Visits: 1.2K
I don't have iClone7 yet, but there is a new morph slider creation feature. I suppose you could round-trip your character+clothing to your modeler of choice, to fix the inevitable pokethrough.
I have foreseen this recurring animator headache from a year ago. Here's my proposal for iClone6 for pokethrough management/ an internal MOVE/ SCULPT BRUSH and MORPH SLIDERS  https://forum.reallusion.com/Topic284674.aspx
Glad to see Reallusion has listened and added the Morph Sliders under Modify panel. They have since added a Sculpting tool to Character Creator. Next they will probably add that Sculpting tool to iClone and solve this major animator headache? Maybe? Perhaps? IT WOULD BE AWESOME! ;) :D
  >>> Indie Generalist modeler-rigger-animator <<< Hardware: AlienWare i7-HK 32G GTX1080 2T-SSDs BenqSW320 Wacom-Intuous 3Dconnexion ||| Software: IC6 Pipeline - CTA3 Pipeline - ATK2 - Indigo ||| Zbrush4R8. Blender 2.79. DazStudio 4.9. Carrara. Poser. Octane.
Bellatrix
Bellatrix
This is the iClone 7 manual link to the morph creation page.
charleshoover885
charleshoover885
Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)
Posts: 105, Visits: 1.8K
I use ZBrush to create a morph slider to  push, pull, or smooth out the clothes as necessary. Works great, easy to do, and makes fixing mashed or wrinkled clothes a snap.
Charles
vidi
vidi
Posts: 10.8K, Visits: 40.2K
I would check in DAZ in the weightpaint modus,  the chest  bone influence for this belt .
In your case, I think.  the influence on this belt still  is not enough.
Maybe you can it fix without extra morphs , only with weight paint  on the Belt
For that .  select Left Chest Bone  and paint (add influence) red Color on the belt mesh, maybe a little bit smooth paint,   too
red areas means the mesh to follow the bone and blue no influence,
With a  color gradient how strong or smooth will bend the bone the mesh
liebe Grüße vidi
wendyluvscatz
wendyluvscatz
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Posts: 2.5K, Visits: 19.4K
it uses the smoothing modifier in DAZ studio
Many PA's get a bit sloppy with their weighpainting because of the handy existence of this tool
Hence fixing it as Vidi suggested probably needed or alternatively convert it to a prop in DAZ studio then use the transfer utility under edit figure to fit it to the base figure, it may stretch and distort a bit with morphs but should follow the figure.
vidi
vidi
I think not, because it is already binded  to the bones , it need only a little bit tweeking in the chest  weightmap
liebe Grüße vidi
Inkubo
Inkubo
I believe I understand, Vidi. You are saying that while I'm still in DAZ Studio with the dressed character, I should go into the clothing's weight painting mode and add influence before exporting to FBX.
I will try it! Thanks!
charleshoover885
charleshoover885
Sounds like a lot of work to modify DAZ clothing that only needs to be adjusted in specific cases in iClone.
The morphs can be applied as needed and controlled in the timeline.
Charles
vidi
vidi
Not more than create a morph and it will be a permanent fix
liebe Grüße vidi
