Getting a .skp file error when importing.
Posted By Combatcommandcat 9 Years Ago
Combatcommandcat
Combatcommandcat
Senior Member (480 reputation)Senior Member (480 reputation)Senior Member (480 reputation)Senior Member (480 reputation)Senior Member (480 reputation)Senior Member (480 reputation)Senior Member (480 reputation)Senior Member (480 reputation)Senior Member (480 reputation)
Posts: 8, Visits: 62
I have noticed that I keep getting this persistent error whenever I try to download .skp files from 3d warehouse.  This seems to occur with large downloads, say 20mb or more.  Is there a work around or fix to this.  I have tried earlier versions of these models like 3dxchange suggests but to no avail, I still receive the same error message.
Posts: 15.8K, Visits: 31.4K
3DXchange is still a 32-bit application, so there is a limit to the size of the models. (Hopefully, 3DX 7 will be 64 bit.)
What you can try is to split the model up in smaller parts in SketchUp, and then convert each of the parts. I've had to do that was a model of a city.
Sometimes it also helps to a apply a patch to 3DXchange that it allows it to use more than than the standard 2 GB of RAM (which is a 32-bit OS restriction) and increases that to about 3.5 GB.
If interested, here is the patch: http://www.ntcore.com/4gb_patch.php. Run the .exe; it lets you then select which application to patch. Navigate to where the 3DXchange .exe is located and apply. It will make a backup so you can always go back. I've used it successfully for years.
Combatcommandcat
Combatcommandcat
Animagic,
Thanks for the fix that is EXACTLY what the problem was I hope that others will see this post and it helps them as well.  I have had no problems since this fix. Thanks again for your help
Sincerely
