make characters/props invisible until certain point in scene
Posted By bpkantor 8 Years Ago
bpkantor
bpkantor
Veteran Member (866 reputation)Veteran Member (866 reputation)Veteran Member (866 reputation)Veteran Member (866 reputation)Veteran Member (866 reputation)Veteran Member (866 reputation)Veteran Member (866 reputation)Veteran Member (866 reputation)Veteran Member (866 reputation)
Last Active: 8 Years Ago
Posts: 16, Visits: 92
Hi all,
How do you make a character or prop invisible until a certain point in a scene? I added "Visible" in the timeline editor to one of the characters, right-clicked, toggled on and off, and somehow got it to work.
However, I tried the same method with a moving prop and it did not work.
Kevin.S
Kevin.S
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.2K, Visits: 71.8K
This works for everything moving or not also on particles, clothing, props, characters, terrains, anything that has a material opacity setting.
1 Select the prop
2 Go to modify panel
3 Select materials tab
4 Scroll down to material settings
5 Adjust opacity slider from 100 to 0, go to the frame you want the effect to start in the timeline, then
adjust the slider, then go to the frame you want the effect to stop, again adjust the slider and your done.
how fast or how slow you want the change is up to you ...
Note:
1 To do this with some props and characters, you have to adjust the opacity for each material item, in the materials list
2 For the best over all look turn the props shadow resolution down to 512x512.
Project view...
I used the same effect with the hologram appearing at the start
Quick render
Cheers :D
Freelance Artist Kevin.S
https://forum.reallusion.com/uploads/images/57cedd8e-58c4-42ce-b2f4-9646.png https://forum.reallusion.com/uploads/images/5a59e070-66a0-4914-b0a5-b2dc.png
Email: animatemyart@gmail.com - Web Site:  www.animatemyart.com
Posts: 8.2K, Visits: 26.5K
"Opacity" is one way of doing it.
It has the advantage of being a gradual change from visible to invisible, if you want.
To make that a sudden change, you will need to use a "Step" function on your keyframe.
In most cases, I would recommend using the "Visible" setting on the Modify panel.
It is a simple On/Off setting.
You can see the results very easily on the timeline.
https://forum.reallusion.com/uploads/images/94006af4-4bb7-49b6-9f32-c417.jpg
Kevin.S
Kevin.S
justaviking (2/11/2017)
Its the same with opacity, Go to frame 1 turn opacity to 0,
Go to frame 2 , turn opacity to 100  on off 1 frame but with the opacity slider you can add motion sizing textures etc etc
With the visible selection you cant .. :D
True.
That reminds me of before I learned about the Step function (learned about its existence) in the timeline eons ago, I would go to say, frame 337, set a value, and then go to frame 338 and change the value.  The effect was that of a step function, but with more work.
The main thing is to be aware of the variety of tool at ones disposal.  I was simply pointing out another option.  :)
bpkantor
bpkantor
Awesome, thank you for all your helpful responses!
