Floating Grass and weeds
Posted By GSR 8 Years Ago
GSR
GSR
Veteran Member (680 reputation)Veteran Member (680 reputation)Veteran Member (680 reputation)Veteran Member (680 reputation)Veteran Member (680 reputation)Veteran Member (680 reputation)Veteran Member (680 reputation)Veteran Member (680 reputation)Veteran Member (680 reputation)
Posts: 6, Visits: 129
ok I am new to this and I have watched many Videos on how to use this program
But I have a serious problem with Grass floating a couple feet off the ground.|
I have tried Snap to terrain, and follow,  this is not werking
any help would be nicehttps://forum.reallusion.com/uploads/images/c2551641-1286-4592-b84c-04e3.jpg
https://forum.reallusion.com/uploads/images/92aeff26-e90e-4619-9d8f-3784.jpg
Kevin.S
Kevin.S
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.2K, Visits: 71.8K
Are you putting plants down one by one or using the gardening tool ?
Sometime you will have to just click on the plant and adjust it yourself, it also depends on the kind of terrain you are using.
Freelance Artist Kevin.S
https://forum.reallusion.com/uploads/images/57cedd8e-58c4-42ce-b2f4-9646.png https://forum.reallusion.com/uploads/images/5a59e070-66a0-4914-b0a5-b2dc.png
Email: animatemyart@gmail.com - Web Site:  www.animatemyart.com
GSR
GSR
It seems I need to Select the Terrain I am trying to Garden
I tried to place a plant and it goes to 0.0.0, I am unable to move them at this time Gardening seems to werk just fine right now
I did solve my own problem lol but thank you https://forum.reallusion.com/uploads/images/0caf1317-ac43-49c9-a66d-f3cf.jpg
Last Active: 11 minutes ago
Posts: 8.2K, Visits: 62.6K
It looks like your using a mesh terrain (rather than a heightmap terrain). Mesh terrain has an option to use its bounding box as its surface, but you would want this turned off in this case. You would use it to save resources if your terrain object only needed a flat surface on top. In your case you want the actual mesh to be the surface for planting.
Select the terrain in the scene manager.
In the modify panel, un-check to "use bounding mesh" option.
Now plant on the terrain.
https://forum.reallusion.com/uploads/images/9a67bc39-d7e2-47d2-bf6c-34e5.jpg
GSR
GSR
Wow ok thanks for the tip
like I said I am new and learning :)
