Is it possible to export iProp to FBX? I'm getting an error message.
Posted By GreedyPeopleSuck 8 Years Ago
GreedyPeopleSuck
GreedyPeopleSuck
Last Active: 6 Years Ago
Posts: 94, Visits: 357
1) Sculpted a prop, imported it to iClone as an iProp.
2) I animated it with keyframes, no physics. Put the relevant animations organized in the Perform menu.
3) I tried exporting it back to 3DXchange and this is what it says:
https://forum.reallusion.com/uploads/images/47fc310e-12e5-41b8-88a7-a8f6.png
There is only documentation to go the other way as far as I can tell, but other people are able to do it. https://www.reallusion.com/iclone/help/3dxchange4/pro/Converting_Model_with_Animations_to_iProp.htm
I have pipeline version of 3DXchange.
Edit: Four years ago it wasn't possible: https://forum.reallusion.com/PrintTopic158708.aspx
Edit 2 for webmaster: The forum is indexed by google by the PrintTopic links. You need to remove these links in the sitemap. Google and Bing are much better for searching the forum than the native search, but every result is with this annoying print link. Using ASP is a nightmare. So many weird quirks that occur.
Last Active: 7 days ago
Posts: 15.8K, Visits: 31.4K
There was recent discussion about this. Any animation in the timeline will be ignored, but what you include in the Perform menu should show up in 3DXChange.
To test I performed the following steps:
1. Create a simple animation on the timeline and add it to the Perform menu.
2. Clear all animation as its no longer needed. (Do not use Remove Object Animation as that also removes the Perform for some reason.)
3. Export to 3DXchange. You should not see the error message and the Perform is listed in the Animation Library:
https://forum.reallusion.com/uploads/images/61ef79f7-34d5-4e93-974e-ed27.png
Now I also tried this with leaving the original timeline animation in place and apart from getting the error message, the Perform motion is still imported as well. Since you used Perform its not quite clear why it didn't work.
I did find that it was easy to "lose" the Perform, so I had to make sure it was there before I exported.
To add multiple Performs, you can repeat Steps 1 and 2 for each. The Perform items will appear in 3DXchange.
GreedyPeopleSuck
GreedyPeopleSuck
animagic (1/28/2017)
Thanks, this works with just one in the perform menu even though I get the same error message. Very strange, and thank you for not only the answer, but confirming I'm not going crazy.
