alfhak
alfhak
Last Active: 8 Years Ago
Visits: 102
You can compare it to this render that is done only with iClone6 and one Directional light!
alfhak
alfhak
Visits: 102
Here is another test image I made today and after 30 minutes render it looks like this! I turn of the iClone Directional light and only used Indigo sun! I set the sun at midday and also position it more or less in front of the scene! I guess it get dark cause of sky prop in the scene!
Posted 10 Years Ago
Enhanced answer... now with pictures! :) In iClone, you can specify a number is Samples Per Pixel ("iterations") or a time limit (in seconds) for each image. You can only set that in iClone if you are doing an animation sequence. For individual images, it is easy to set the limits in Indigo itself. First you have to STOP (not pause) an existing render. Then on the "Render" menu (on the right side of the screen in my setup) you can pick the drop-down menu to access "Render Settings." There you can specify a Time (in seconds) or a SPP (Samples Per Pixel) at which to stop. The "-1" indicates infinity. If you set both Time and SPP values, it will stop at whichever limit it reaches first. Please share a picture of your results.
Posted 10 Years Ago
You can set it to stop after a certain amount of time or a desired number of iterations. So if experience with an image tells you it looks good after 380 iterations, you could set it to stop at 400 (a bit extra, just to be sure).
I don't have screenshots at the moment because I'm away from my main computer.
alfhak
alfhak
Posted 10 Years Ago
Visits: 102
Thanks Garry! I begin to wonder, cause I thought it should stop by itself then it was finished! it would be easier if it did so you know you don't stop it to early! I will stop it now!
Alf
Posted 10 Years Ago
Last Active: 3 days ago
Posts: 5.7K,
Indigo will render the image until you stop it. You can do this when the image doesn't seem to be showing any signs of improving visually.
alfhak
alfhak
Posted 10 Years Ago
Visits: 102
More than 70 minutes have passed now and it still working! LOL Does it never stop and finish? Alf
alfhak
alfhak
Posted 10 Years Ago
Visits: 102
I have iClone 6 and downloaded the trial for Indigo RT! I just made a simple image with two avatar! Do the same way as the tutorial! A photo of the head with camera and then use Indigo lightning! Just tick the boxes and lower the sun and change the angle from it! Export it to Indigo for render! Now it has continue render for over 52 minutes in Indigo RT! Is that normal?
Alf
