iClone 6.5 & CC 1.5-compatible iAvatar Export
Posted By Miranda (RL) 9 Years Ago
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Character Creator  2.0 is compatible with both iClone 6.5/CC 1.5 and iClone 7. When exporting iAvatar in Character Creator  2.0, there is an option to select which version of iAvatar will be exported.
Use the Version pulldown menu to select the desired type.
Character Creator 1.5 & iClone 6.5 version does not support PBR, so PBR information will not be included in the export file.
Check Online Manual HERE.
 The following data will not be carried by Character Creator  2.0 Beta when exporting in iClone 6.5 & Character Creator  1.5 avatar format:
  1. Texture strength parameter
  2. Reflection and refraction parameter
  3. Blend map parameter
  4. Floor contact enable/disable
  5. Default pose and persona
  • Items 1,2,3,4: iClone 6.5 will revert to original settings.
  • Item 5: Default pose will revert to iClone 6.5 settings but Persona needs to use 3DX PRO or Pipeline version to continue usage.
