pro vs. pipeline versions
Posted By revonder 8 Years Ago
revonder
revonder
Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)
Posts: 1, Visits: 10
Which the difference between using the version "pro" and the version "pipeline" of the products crazytalk 8 and crazytalk animator 3? Thanks by any attention. I have the version "pro" and want to acquire the version pipeline. Is it advantageous?
jlittle
jlittle
Last Active: 3 minutes ago
Posts: 1.9K, Visits: 17.1K
You can view the version differences for CTA HERE.
  • Create G3 Characters Directly from PSD Format (coming feature)
  • Customize Full-body Multi-angle G2 Characters
  • Create Vector-based Character, compatible with Multiple Render Style
  • Create Vector-based Character, compatible with Multiple Render Style (coming feature)
  • Custom Design Elastic Motion Effects using Key Frame Animation
  • Import 3D Motion (iMotion and RL Motion from iClone), BVH/FBX (via 3DXchange
For CT the differences can be found HERE.
Basivcally the Pipline version adds to the Pro the following:
  • Import iAvatar
  • Face export to iClone (v6.3 above)
  • Face export to Character Creator
  • Script file export to iClone (v6.3 above)
Which version you use depends upon what you are trying to do.
Review the differences and if you need any of the Pipeline features to obtain your goals then you should get the Pipeline version.
Jeff
