Drawplus to CTA2 G2 character creation
Posted By billcheung65 9 Years Ago
billcheung65
billcheung65
Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)Senior Member (409 reputation)
Last Active: 9 Years Ago
Posts: 2, Visits: 16
Hi there - I am attempting to create a new character based on the template file. I traced the image from a hand drawing in Serif Drawplus X6.
https://forum.reallusion.com/uploads/images/9afa5e44-1dff-4adf-afb5-e140.jpg
After that, I loaded up the template file for the G2 character and tried to replace each body part piece by piece, keeping track of the layer names. I started with angle 0 to make sure it worked.
https://forum.reallusion.com/uploads/images/f8709e05-5d25-4dc5-a041-de96.jpg
 I got as far as the arms and hands. I soon as I tried to insert the Upper_torso_0, this is what the exported SWF file came into CTA2 as. There was no error report but obviously something is wrong. Do the drawings need to be completely symmetrical? Does linear shaded fill mess things up? Any idea what I am doing wrong? This has been frustrating me for weeks and so I am reaching out to the community for help as I am sure someone has run into this before.
Thanks in advance!
https://forum.reallusion.com/uploads/images/ae030fe7-7df6-4286-947c-84ef.jpg
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
billcheung65 (11/13/2016)
No.
Yes.
There are several things to keep in mind when using vector drawing:
1) All shapes must be closed! Otherwise it is converted into a bmp image.
That means that any line you draw must connect back to its starting point.
Any shape you draw must be closed.
There is a "close shape" button in DP that you can use to close a shape.
2) If you use gradient shading, the image is turned into a bmp image and is no longer a vector image.
You must simulate shading using additional shapes of SOLID colors.
Jeff
