Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
I guess I was not in step... :blush: Thanks for the link, Wendy, and the additional information, Pumeco!
pumeco
pumeco
Posted 10 Years Ago
Group: Banned Members
Last Active: 9 Years Ago
Posts: 1.3K,
Visits: 3.2K
Excellent find, Wendy, that software at the link it mentions (ambiX) looks spot-on, it's even available on Linux, which is great cause that means it should work in LMMS (also Linux or Windows). http://www.matthiaskronlachner.com/?p=2015 https://lmms.io/Yup, veeeeeeeeery nice, that's the one I'll be using just as soon as I have a video to use it on :D Why do you mention maybe needing coding or scripting ability, though?
wendyluvscatz
wendyluvscatz
Posted 10 Years Ago
Last Active: 4 Months Ago
Posts: 2.5K,
Visits: 19.4K
https://support.google.com/jump/answer/6400185?hl=enthis is how they do it you would need to have coding/scripting ability by looks, I certainly could not do it, will need to wait until someone makes an app. I think it amounts to a 5.1 channel audio track conversion, so if you can make a 5.1 audio track that would be a start, iClone only does stereo so it would need to be post edited in a videoeditor that supports it.
pumeco
pumeco
Posted 10 Years Ago
Posts: 1.3K,
Visits: 3.2K
Cheers Rampa, that does look very cool and capable, no mention of price though, so we'll see! Good to know the system will work with any DAW that supports VST, and there's nothing special required :cool:
Posted 10 Years Ago
Visits: 62.6K
pumeco (11/14/2016)
Which VSTs, are you aware of any specific? I just had a quick search for 360 VST, and all I can find is something from Waves and a few 360 reverbs. Not changing my DAW/s so can't go that route.
I get the feeling I might have to wait and see what Magix does with Acid and Vegas now they own them.
http://dysonics.com/first-look-at-rondo360-vr-audio-software/
pumeco
pumeco
Posted 10 Years Ago
Posts: 1.3K,
Visits: 3.2K
Which VSTs, are you aware of any specific? I just had a quick search for 360 VST, and all I can find is something from Waves and a few 360 reverbs. Not changing my DAW/s so can't go that route. I get the feeling I might have to wait and see what Magix does with Acid and Vegas now they own them.
Posted 10 Years Ago
Visits: 62.6K
There are VST plugins for the major DAWs that do it. It'll be in a few video editors soon, if not already.
pumeco
pumeco
Posted 10 Years Ago
Posts: 1.3K,
Visits: 3.2K
@RampaYup, that's exactly what I'm getting at! That's the first one I've seen with that ability but at least it has a suitable audio format. Don't agree with the name it has though, if that's the official term, "Spatial Audio" is something usually associated with psychoacoustics, and while there is some involved, the term "Spatial" is already taken and accepted in audio circles. I reckon they thould have called it the 'Audio 360' format or someting like that. Anyway, that's great news, I'm glad it exists but the problem now then is that iClone doesn't have the ability to place soundfiles in it's scenes to encode the 360 audio with the movie :doze:
I feel a request coming on! @JobLooks like it's already here, lol, but as for doing it in iClone, it would probably be done by attaching soundfiles to objects in your scene. Like if you had a running tap, you'd just attach the sound of a running tap to the model of the tap in your scene. Same with any other object in your scene that would make a noise. Then when you output the movie to 360, iClone uses the position of the objects to decide how it encodes the audio in it's 360 panorama. Sounds as if that's how it's done in that VRML stuff you mentioned. I've never used VRML so couldn't say, but it sounds like it from your description. I'll have to look into the format those 360 videos are using and see if it's possible to add the 3D sound after the movie has been output without it. Form the description in that video it's based on surround sound, so it's probably possible to do it in any editor capabale of editing and encoding surround sound :w00t:
Times like this I wish I had Vegas Pro instead of Platinum :Wow:
Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
Responding to pumeco: Well, yes, but where would the sound come from? (Speaking of iClone, obviously.) For example, I don't rely on the audio in iClone other then for lip-synching, and currently there is no mechanism where the sound attached to a prop or an avatar is placed in space. But even that wouldn't even be enough; each sound would need its own channel that is then dynamically combined in a kind of surround mix. It is an interesting problem and it would be cool, but I don't believe it's simple to solve for recorded media. But I agree, it would do more to immersion than stereoscopic VR as someone requested the other day. A long time ago there was something called VRML (VR markup language), which was aimed at creating a 3D environment you could move through with any sound emitters being adjust as you traversed the environment. It was very crude, and the home PC wasn't really powerful enough, but it was compelling. VRML is obsolete, but apparently people are looking at modern equivalents. See for example here: http://www.web3d.org/event/w3c-workshop-web-and-virtual-reality. So what you want may actually be around the corner.
Posted 10 Years Ago
Visits: 62.6K
Well. It seems to exist.
