I have attempted to create elastic motions but I find there is an issue in that when using the Elastic Motion Editor's "Duration" setting it repeats the motion rather than stretch it out like it does for the given elastic motions.
The process I use is as follows:
1) Use Prop Key Editor to modify Prop with desired motion, rotation, opacity.
2) Collect clip and export
3) Clear props animation (or start with new prop)
4) Import Motion to props motion track
5) Convert to Elastic Motion
6) Export Elastic Motion
Is this the correct process for creating elastic motions?
What am I missing?
Jeff
