Hi All,
iClone 7 with PBR support have been released and Marketplace now has support for Hi-Res images, so I'm ready to introduce my new packs with PBR support
As usual all these packs can be found in the
Bigboss Treasures Store.
PRCC Male Sci-Fi Armor SetThis set includes 3 packs on Your choice:
PRCC Male Sci-Fi Armor Bases
NOTES: Cloth models in this pack have been created for CC Male character and it's not recommended to use them with female.
What in pack:This pack includes 3 base models - body suit, gloves and helm. Each of them can be used separately or combined with other pack's models. Body suit is solid model which in fact consist from 3 parts (Upper, Lower and Shoes).
All base models have high resolution (up to 2K) set of basic textures required for successful PBR materials construction in CC Appearance Editor - RGB Masks (6 IDs), Normal Maps, World Normal Maps, AO and Curvature. Base models have no pre-defined Fabrics and You can define fabrics and effects as You like.
Also in pack:PRCCM_SF2.zip file includes copies of RGB Masks for base models and documentation.
Please read this documentation before using the pack.
This pack consists from 3 parts:
- Male Sci-Fi Armor base models for use in CC2;
- Photo realistic materials for them for use in iC7.
- Additional content.
Base models in pack:This pack includes 3 base models - body suit, gloves and helm. Each of them can be used separately or combined with other pack's models. Body suit is solid model which in fact consist from 3 parts (Upper, Lower and Shoes).
Materials in pack:The pack includes 5 photo-realistic PBR materials for base models which can be applied in iC7:
- PRCCM_SF2Suit_L.iMtl and PRCCM_SF2Suit_U.iMtl for suit (2K resolution each);
- PRCCM_SF2Gloves.iMtl for gloves (1K resolution);
- PRCCM_SF2Helm.iMtl (1K) and PRCCM_SF2Helm_Glass.iMtl (0.5K) for helm.
Also in pack:- ColorTune substance tools allow to tune cloth colors directly in iClone using RGBMasks.
- Sci-Fi Pistol (PBR) and gesture for it.
- PRCCM_SF2.zip file includes copies of RGB Masks for base models and documentation.
PRCC Male Sci-Fi Armor Materials
This pack includes only iC7 materials for armor and can be used as addition to "PRCC Male Sci-Fi Armor Bases" pack
CC Head Morph "Ray"
PRCC Male Head Ray
NOTE: Full head morph included in this pack have been created for standard CC Male Base character. You can combine it with other head morphs but in this case You will lost original head shape shown on pictures.
This pack includes :PRCCH_Ray.ccSlider - Full head morph for CC Male base character.
Photo-realistic PBR materials for Ray head (can be used in iClone 7):
- Two versions of head skin materials (2K) -- PRCCH_Ray_SkinHead_Bald.iMtl and PRCCH_Ray_SkinHead_Shaved.iMtl
- Eye materials (0.5K) -- PRCCH_Ray_Eye.iMtl and PRCCH_Ray_EyeCornea.iMtl
- Eyelashes material (0.5K) -- PRCCH_Ray_Eyelash.iMtl
Two ready-to-use CC Male character bases with applied Ray head morph and textures -- PRCCM_Ray_Bald.ccProject and PRCCM_Ray_Shaved.ccProject
Documentation in the PRCCH_Ray.zip file.
Please read documentation before You start to use this content.
Sci-Fi Outfit PBR Packs
PRCC Male Sci-Fi Outfit PBR
NOTES: 1. Cloth models in this pack have been created for CC Male character and it's not recommended to use them with female.
2. To avoid DRM issues this pack includes previously published Cloth Bases with "Traditional" shader, but because these bases already have all necessary Mesh Data textures You can easy create PBR version of them using step-by-step instruction from ZIP file.
If You already have this pack cloth bases You can purchase "PBR Materials only" version.
The pack includes 5 cloth bases and 5 ready-to-use PBR materials.
Base models oriented on use as templates in CC Appearance Editor -- they have all main textures (Normal, AO, WS Normal, RGB Mask with up to 2K resolution) and empty Fabric definition (You can define fabrics and effects as You like).
Materials have .iMtl file format and can be applied in iClone7 (resolution of textures up to 2K).
What in Pack:- Upper -- 3 Bases and 3 Ready-To-Use materials;
- Lower -- 1 Base and 1Ready-To-Use materials;
- Shoes -- 1 Base and 1Ready-To-Use materials;
- PBR version of SciFi Pistol Accessory with Ready-To-Use materials;
- Hands Gesture for SciFi Pistol;
Also in pack:ColorTune substance tools which allow to tune cloth colors directly in iClone using RGBMasks.
PRCCM_SF1_PBR.zip file includes copies of RGB Masks for base models and documentation.
PRCC Female Sci-Fi Outfit PBR
NOTES: 1. Cloth models in this pack have been created for CC Female character and it's not recommended to use them with male.
The pack includes 3 cloth bases and 3 ready-to-use PBR materials.
What in Pack:- Upper -- 1 Bases and 1 Ready-To-Use materials;
- Lower -- 1 Base and 1 Ready-To-Use materials;
- Shoes -- 1 Base and 1 Ready-To-Use materials;
PRCCF_SF1_PBR.zip file includes copies of RGB Masks for base models and documentation.
PRCC Sci-Fi Pistols PBR
Pistols models in this pack constructed not only as Accessory but also as Props with special Reach Target objects which allow easy and correctly attach it to both left and right hands (see instruction in .ZIP file). Because of difference in male and female hand sizes the pack includes two version of pistols and handle gestures for them.
Pistols have photo-realistic PBR materials.
What in pack:- 2 Sci-Fi Pistol models (as Accessory) for male and female;
- 2 handle gestures for these pistols;
- documentation and pistol display template in .ZIP file.
Sci-Fi Packs PBR Upgrades.These packs can be useful for those who already have previous (not PBR) versions of Sci-Fi content.
PRCC Male Sci-Fi Outfit PBR Materials
PRCC Female Sci-Fi Outfit PBR Materials
PRCC Sci-Fi Pistols PBR Materials
Hope You will find this content useful.
Have fun
Vit
