Hi all,
Iclone is crashing when you are exporting longer films to Indigo. E.g. when you export the abandoned house scene that comes with Iclone 6. Reason is a memory error in the RAM. The bug has been confirmed by RL but they are not doing anything on it, though they originally promised to fix it with 6.5. Therefore please kindly support the issue :
http://www.reallusion.com/FeedBackTracker/Issue/Bug-that-makes-Iclone-crash-when-you-export-to-Indigo========================================================================================================================
UPDATE:
I did start to work with Indigo again and finally was able to export on a new Machine 619 Images without problem.
Reason : Little number of Polygons and 32GB of RAM
NOW:
the interesting observation is : after the Iclone Plugin finished the export successfully Iclone is using 23 GB of RAM.
Meaning : The export is done and still Iclone is a memory beast (when the export started the RAM Usage was around 600MB for Iclone)
RL TEAM:
Please pick this topic up !
Machines :
MSI Gaming Laptop, I7, GTX 1080, 16GB RAM, 512GB SSD, 1 TB HD
Acer Predator Helios 300 I7 10750H, 16GB, 1TB SSD, RTX 2070
8 Years Ago by
sbaerman
