Edit Sprite Image in Photoshop?
Posted By iamsikora 9 Years Ago
iamsikora
iamsikora
Veteran Member (773 reputation)Veteran Member (773 reputation)Veteran Member (773 reputation)Veteran Member (773 reputation)Veteran Member (773 reputation)Veteran Member (773 reputation)Veteran Member (773 reputation)Veteran Member (773 reputation)Veteran Member (773 reputation)
Last Active: 9 Years Ago
Posts: 10, Visits: 16
Thanks so much! It was a PNG, so easily editable!
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
CTA does not provide a means to edit vector sprites, only bitmap image sprites.
If you have your preferences Texture Editor set to PS then in Character/Prop Composer you can "Launch External Image Editor" to change the bitmap image selected.
If you are trying to modify a vector based (i.e. SWF) sprite, then you must recreate it and replace the existing one.
You can show and enlarge only the sprite/image you wish to modify and use a screen capture (F10) to get an image you can trace over to recreate it.
Note that most RL character sprites are vector and not bitmap.
Jeff
iamsikora
iamsikora
How do I get the file/body part sprite and edit it in Photoshop? I only see a way to replace it entirely, but I'd love to edit the current image file and replace it with an updated one.
