VirtualMedia
VirtualMedia
Visits: 19.0K
Good call, this one bites me all the time.
Virtual Media® / VTV® / The Virtual Entertainment Network... http://VTVLive.com
Posts: 4.9K,
Visits: 16.7K
Thanks for exposing this naughty little bug!!!! :P:P
Yay! Status = "Active"
Thanks for revisiting it, Reallusion.
Yeah, they marked is as "Not Reproducible" so I figured I'd help.
I always say, a bug that can be reproduced is 80% fixed.
Delerna
Delerna
Posts: 1.5K,
Visits: 14.8K
That happens to me all the time. And yes only when zoomed out. Looks like you are on the key frame but your not
Zoom out to see where you are in the film sequence Zoom in to make sure the keyfame is selected Make the change Zoom out to see where you are in the sequence while testing Zoom in to make sure you are on the keyframe Make the change Zoom out to see where you are in the sequence while testing
Its a real pain when fintuning an animation
i7-3770 3.4GHz CPU 16 GB Ram GeForce GTX1080 TI 11GB Windows 10 Pro 64bit
I created this post so I can ADD PICTURES in support of a Feedback Tracker issue. (You cannot add pictures to comments, so I'm doing it the hard way.)
ISSUE #407 http://www.reallusion.com/FeedBackTracker/Issue/It-s-too-easy-to-create-a-duplicate-Keyframe-in-the-timeline
SHORT SUMMARY: Clicking *near* an existing keyframe will turn it green, so it looks like it is selected, but in fact you can be a couple frames away, so any "editing" will result in a *new* keyframe rather than modifying the existing one. This is probably more likely to occur when you are "zoomed out" on the timeline.
NOTICE: a) The Frame counter b) The keyframe that turned green c) The new keyframe that appeared when I moved the avatar's fingers, so now his hand "jumps" from the old pose to the new pose in the span of two frames
