Is it too much to ask for that 3DX shows exactly what a model will look like in Iclone
Posted By bluemidget666 10 Years Ago
Is it too much to ask for that 3DX shows exactly what a model will...
bluemidget666
bluemidget666
Posted 10 Years Ago
Last Active: 10 Years Ago
Posts: 3.5K, Visits: 13.8K
Just wasted 6 hours assuming the 3DX 5&6 showed how the model will be in iclone 5 & 6.
this in 3dx
https://forum.reallusion.com/uploads/images/83cded06-aff0-4de4-9961-d6d0.png
now what it looked like in both Iclone 5 & 6
https://forum.reallusion.com/uploads/images/a56b5da2-e83e-4d0f-8d37-baf1.png
GRRRRTRR and Rudy GRRRRRR again.
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
duchess110
duchess110
Posted 10 Years Ago
Last Active: 6 Years Ago
Posts: 2.0K, Visits: 15.5K
Agree 100% bluemidget666.
I have had similar issues the mesh skinned to Character looks good in exchange no skin poke through, but in iClone 99% of the
time under the armpits the skin shows through. It obviously looses something in the transfer between programmes.
Duchess Designs Store
planetstardragon
planetstardragon
Posted 10 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Posts: 11.5K, Visits: 46.0K
i've seen similar,  i believe it has to do with the bones you chose and the weightmaps they affect.  - it happens a lot with messiah rigs i import actually....I've learned that the less bones you select - minimum requirements -  no extra bones,  the better the model functions. so if by chance you are adding extra bones on your rig in the 3DX retarget mode,  that could be causing it
I know the feeling though,  i basically took a vaca from 3D because every time I pause from making new music to make videos,  I'm bombed with a ton bugs and spend more time figuring out work arounds than actually getting stuff done ....   it just burned me out last round and I actually abandoned my latest video project,  and can't finish 2 gigs because of it...heh...
"To define Tao is to defile it" - Lao Tzu
bluemidget666
bluemidget666
Posted 10 Years Ago
Glad its not just me then soo annoying.
The bone explanation makes sense, its a make human model  with extra bones around the collarbone and breast because the ones with less bones just would not rig right.
So now I know the issue I have a way forward but still 6 hours gone because 3DX works different to Iclone.
That is SOOOOOO annoying, so I will be starting from scratch again tomorrow instead of finishing tonight.
I am still very much in the GRRRRRRRR frame of mind. :)
P.S did i mention how annoying this is ?
Posted 10 Years Ago
Last Active: 5 hours ago
Posts: 8.2K, Visits: 62.6K
Makehuman characters can be very tricky that way. You need to check with some different poses in 3DX. Looks like you were just using the t-pose. If you put the character into a t-pose in iClone, it should look the same.
Make sure you are using the Makehuman 1.1. I think it is still the "nightly", but it has a t-pose to set the character to before exporting. that will really help. But yeah, it's the same weighting issue that I ran into a lot!
bluemidget666
bluemidget666
Posted 10 Years Ago
Hay SwoooooP
can I fix the fbx version in 3dmax ?
bluemidget666
bluemidget666
Posted 10 Years Ago
If I exported a fbx version from 3dx is there anything in max that would fix the issue.
bluemidget666
bluemidget666
Posted 10 Years Ago
Its going to be about an hour before I can get on the comp can you elaborate a bit on how to do your steps after importing the fbx.
cheers
bluemidget666
bluemidget666
Posted 10 Years Ago
For this I will be using max 2016.
I see now that the issue is as Rampa described (Sorry RL)
the there is 0 weigh on the chest area.
So I am not sure if a start from scratch approach is a better option
bluemidget666
bluemidget666
Posted 10 Years Ago
Its a make human mesh but I have shaped it well over its limits :(
So the chest area is not being effected and you can see where the weight mapping influence  ends.
https://forum.reallusion.com/uploads/images/7c5c626e-54ad-4a99-9e8e-fd62.png
