Iclone Material Tutorial
Posted By shil 9 Years Ago
shil
shil
Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)
Posts: 11, Visits: 175
Hi there,
I'm looking for a serious Iclone Material Tutorial. Can someone advice me please.
I'm not talking about the Indigo Render. Just Iclone 6.
Was searching on reallusion.com, youtube and forum. Without big success.
Many Thanks.
Xialin
Last Active: 4 Months Ago
Posts: 5.7K, Visits: 26.5K
Since you haven't bothered to mention just what sort of Material/Texture you wish to apply to what item/surface, it's rather difficult to know where to start. For texturing G5 Clone Cloth I'd suggest the excellent tutorial by Alley in this post - works quite well for G2 and G3 cloth also.
shil
shil
wires (1/31/2016)
thank you, wires.
I'm beginner, so i would just find some tutorials for basic and advanced principles for good texturing and NICE render in iclone. I don't looking for the same quality than 3ds or cycles render in blender of course, :),  but something good looking. So have to start with a good knowledge about materials.
Posts: 23.1K, Visits: 36.6K
xialin (2/1/2016)
If you are new to iClone then I would advise watching the two "iClone Beginner's Guide To Scene Creation" tutorials below. These cover the basics including adding materials into your scene and is a great starting place.
https://www.youtube.com/watch?v=rvlSi1jLl54
https://www.youtube.com/watch?v=rUX2ZsyowjY
Posts: 8.2K, Visits: 26.5K
@Xialin,
Greetings, and welcome to the iClone family.  I hope you're still here.
To help restart this thread for you, a couple of key points (in my opinion) are:
a) A quality diffuse map, meaning a nice high-quality and good-resolution image.  You don't need a 2048x2048 pixel image for a small prop that never fills much of your screen, but larger objects that you zoom in on will benefit from a good diffuse map.
b) Bump maps make a huge difference to me.  They really help give the appearance of "texture" to anything that's not perfectly flat.  Even a rough canvas can benefit from a good bump map if you get close to it at all.
Also:
c) Specular maps also help add some life to objects
d) More technical, but a good UV map (how a 3D model is "unwrapped" to a 2D surface) can be extremely important, but iClone has no control over it.  You need to do that part in an external modeling tool.
This should help inspire more people to chime in.  Please ask more questions to help us help you.
ADDED LATER:
e) Lighting.  Good lighting helps everything look better, and adds to the "mood" of your film.  It is one of many areas where I need to (vastly) improve my meager skills.
MORE ADDED LATER:
Here is one, fairly simplistic example of why I featured "bump maps" as a way of making good materials.  It's not just the "material" but the prop itself.
In this example, the geometry is smooth and featureless.  The bumpy texture is simply a result of the "bump" map which give the appearance of highly detailed geometry.
That keeps your model very lightweight (low-poly... few numbers of polygon faces) while still looking good.
The bottle on the left has flaws.  It's NOT a best-in-class example, but it does demonstrate the value of a bump map.
(The ridges on the red and yellow caps are also due to bump maps, not geometry.)
https://forum.reallusion.com/uploads/images/7b8ba4ac-97d7-4ba3-8861-225e.jpg
shil
shil
@peter     thank you peter. I started just to check the tutorials about scene creation. I think they will do the job. Will be a good starting point.
@justaviking     I know already some of your tutorials from your youtube channel (smooth camera movements, lights (and masson)). Happy and thankful to read your answer here. Very useful.
Many thanks.
xialin
