HELICOPTER ROTOR ANIMATION
Posted By richard666 10 Years Ago
richard666
richard666
Posted 10 Years Ago
Posts: 74, Visits: 425
thank you for your reply. best wishes
richard666
richard666
Posted 10 Years Ago
thank you so much.......you know i bet there are lots of people wanting to know about this but maybe afraid to ask....i hope it helps everyone. again thank you for your effort and advice.
Cricky
Cricky
Posted 10 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
https://youtu.be/fD3pOKM31LU  Made in Jan 2015, and it still applies
https://youtu.be/ovwU2iDwKuA  Made in 2010, and it still applies.
0 - 179 -  358 -   0   Four Numbers that if spaced evenly for  time line position, in this order, gives a perfect 360 rotation in iClone.
Use the resulting collection of transforms as a perform, and then use the item rotated as a Dummy that rotates anything in a perfectly looping spin.
You can turn it sideways, upside down, or not use it at all; and just add a perform to the Tire or Blades, or whatever.
Just make sure the item being rotated is Centered for it's Pivot.
The shorter the space on the timeline the faster the rotation:
ie..  0 Frame 1, 179 Frame 60, 358 at Frame 90, and 0 at Frame 120 will produce a fairly fast 4 second spin.  This can be stretched to slow it down, it can be shrunk to speed it up. BUT, it will always give you a perfect loop if the FOUR transform KEYS are collected as a NEW Perform command..
SKYPE ID: rc.650
JIX
JIX
Posted 10 Years Ago
Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)
Posts: 1.1K, Visits: 1.3K
Did the same thing (as Kelleytoons described) a couple of months ago. It´s really easy. Good luck!
richard666
richard666
Posted 10 Years Ago
thank you very much for replying. i will try this, best wishes
richard666
richard666
Posted 10 Years Ago
thank you your animation looks good. i bought the helo through iclone thinking it would all work without having to do anything much.....maybe i should just get the freebees and work on them a bit. the model was crap anyway i would not recommend paying 19 dollars for it!!!!!  ive got better free!!
Skuzzlebutt
Skuzzlebutt
Posted 10 Years Ago
Posts: 582, Visits: 8.6K
this may help,
its best if you tried it with a free model first before you commit hard earned cash
http://tf3dm.com/search/?q=chopper&format=All+Formats&search=Search
scroll down the page .the Mi-28N Havoc is obj so compatible with 3dx
next look at this fine tutorial from the great forum user Mark aka smallWstudios
https://www.youtube.com/watch?v=LP7MEE4Pt_4
Posted 10 Years Ago
Posts: 9.2K, Visits: 22.1K
If you have 3DXChange you could bring the model into it and make the rotor a sub-prop as well as choose the pivot point for it to rotate around.
I just brought this free sketchup model into XChange, selected all the rotor stuff, made it a subprop and aligned the pivot, and created this animation:
richard666
richard666
Posted 10 Years Ago
I have purchased a DREAMSCAPE so i could get a turning rotor blade as the chopper moves throught the sky.  The problem is that i have not got a clue how to make it animate /turn. i cannot find instructions anywhere from iClone or DREAMSCAPE.  Can anyone help me or direct me to how i get the rotors to move and the missiles to fire. the helicopter is not worth paying for unless these things move!!.  thanks
