friederike
friederike
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 105
 I have a problem with IClone6.3. The number of the total frames is limitated to 9999. I always need more frames.....Now I found , that it is possible to add frames, but only if you use the "more" button. It is not possible to add frames if you try to input them with a number. The number input is limitated to 9999.
Posted 10 Years Ago
I just put in 30,000 frames (without the comma) and it worked fine. That's over 8 minutes, which would be a very long individual clip.
[Edit] I guess the rest of this is irrelevant if you can't even type in larger numbers (such as 30000), but I'll leave it here anyway... [/Edit]
Did you also remember to move the little "flag" that marks the end of your current working time zone? When I change the total length, the "end point flag" stayed at the 29-second point, or wherever it defaults to. So I had to zoom way out "Fit Window" on the timeline so I could drag the marker flag to the end.
Posted 10 Years Ago
Last Active: Today @ 12:47 AM
Visits: 62.6K
I was able to get it up to 49,999.
First type in 9999, hit enter. Now put a 4 in front and hit enter again.
Double checked the timeline, and it really is 49,999. I tried a 5 in front as well, but nope.
Posted 10 Years Ago
Oops... I must have hit "Quote" when I meant to "Edit" my first post (and Rampa was posting simultaneously). I can't delete this, and I have nothing particularly cute or clever to say at the moment. Oh well.
friederike
friederike
Posted 10 Years Ago
Visits: 105
Thank you...... I did not know, that first you have to put 9999 and then a larger number... in 6.2 this was not necessary.......
friederike
friederike
Posted 10 Years Ago
Visits: 105
In 6.2 it was 54000. If you put in 99999 the program automaticly corrected to 54000. You could do this at the beginning of your work and it did not matter, were you where in the timeline......
Posted 10 Years Ago
Visits: 62.6K
little update. You can type it in directly. It seems the only differences are that it will not correct the number for you, and it only goes up to 49,999.
friederike
friederike
Posted 10 Years Ago
Visits: 105
No... little update..... you can arrive to 54000 if you put first 9999, enter,49999,enter,44000,enter, 54000,enter :)
