brand468
brand468
Posted 10 Years Ago
Last Active: 10 Months Ago
Visits: 7.8K
Hi, "justaviking", The renderings are made directly from iClone as .mp4 1280x720 (no screen capture), then imported to Vimeo. I have a 40 inch screen (3840x2160 resolution), thinking about iClone are not supporting control the high resolution??
My computer: Intel i7-7700K 4.2Hhz 64Gb, Windows 10, GeForce GTX 1080 + GeForce GTX 1070, Phillips monitor 40" 4K 3840x2160 + 2x28"
Posted 10 Years Ago
In the videos you shared (thanks)... Is it safe to assume they are "screen capture" types of videos? If you RENDER to an AVI, MP4, or sequence of images, does that generate a clean video?
brand468
brand468
Posted 10 Years Ago
Visits: 7.8K
Yes, i cant understand what is causing this problem, the graphics card or iClone 6? The problem seems to occur when you are close (zoomed in) on a transparent object, then a pattern with small rectangles seen as more or less clearly depending on the camera angle. Appends two renderings of "The Lounge" seen from the outside through the transparent windows where the pattern occurs in video 1, both are rendered at same settings.
Video 1 = maximized iClone window
Video 2 = window scaled down by half
Lawsuit Pending Records
Posted 10 Years Ago
Visits: 2.1K
I have encountered this before and can't remember for the life of me what I did to solve it. I did not discover the reduced screen makes a difference which might help pinpoint the issue. I run the Nvidia as well and have a few shadow issues. I have a scene where the trees have the tops/foliage as shadows to the ground as normal and with the trunks the shadows are nonexistent I have tweaked and tried everything on that scene. I thought it might have been early days of the Maxwell architecture and was hoping to see future improvement via driver updates and compatibility bugs ironed out from both sides. I remember at the time as it was just after iC6 release I was thinking same about the issue you have.
iC5 Pipeline, iC6 Pipeline, CTA2 Pipeline, CTA Pro, Crazy Talk, Facefilter, POP. LAWSUIT PENDING RECORDS - Label-Logos-Web Design-Artist Roster-Licensing - Flip type interactive magazine production
brand468
brand468
Posted 10 Years Ago
Visits: 7.8K
I have problems with transparent objects (eg transparent walls of buildings) in iClone 6 and have now found something very strange. I simplified objects to a box and a sphere to do some tests. If I place an object in the foreground of a different object and makes it transparent (in this example, a sphere with 35% opacity), so formed a strange pattern (small squares) when I zoom into the object. The pattern is also left when I render image. But this problem occurs only when iClone is maximized.I discovered after much testing that the pattern disappears when I reduce the size of the window? The pattern is also gone when I run a rendering?
I've tried all the settings I can think of and even updated the graphics routines and the latest iClone version. Is there anyone who can explain this, or should I contact support?
Screencapture when iClone is fully maximized
Screencapture screen size reduced to 50%
