...I am ready with the Indigo Version of my short Clip "A short Walk along the River"!
You can enjoy it here:
https://youtu.be/zymQedw91kcCompare it with the Iclone 6 only Version here:
https://youtu.be/etmpE1RNOXkSome Technical details: Used 2x I7-870, slightly more than 1050 Frames were calculated, each Frame with about 800s/p, one Frame took about 40 mins to calculate.
The Iclone to Indigo exporter took quite long(about 1 day), and produced more than 25 Gb of Resource Data, but did NOT crash at all during the conversion.
But unfortunatly Indigo has a very nasty Problem, which stopped it working all the time! One day there was no Problem in calculating multiple Frames from the queue. The other day it simply stopped at samples/p 400 oder 500, mostly right at the End of calculating a Frame at 800samples/p. This means that nearly each Frame had to be restarted manually which made it taking up so much time. Several Frames also had to be rendered twice due to this Problem.
