Question about animating textures?
Posted By Blessdaily 10 Years Ago
Posted 10 Years Ago
Posts: 8.2K, Visits: 26.5K
Some things are best (and most easily accomplished) using a combination of tools.
I recommend using video editing software to overlay your text onto an iClone video.
Inside iClone, you could use the "overlay" object (sorry, I think I have the name wrong).
You see this when you open sample projects that Reallusion provides.
You could also use billboard objects.
But my recommendation is to add text after you've exported the animation from iClone.
You CAN edit iClone material properties, especially if you're using "Substances" for your materials.  But you cannot *replace* one material with another half-way through the video clip.
Do you have some specific pictures you can share to help explain in more detail what you are trying to do?
If you need people to "walk on the text" that's on the floor, you could add several "Plane" objects.  They would be transparent, except for the text.  Lay the play just above the floor.  Then turn the Opacity property from 0 to 100 and back to 0 again to make a specific set of text appear at the right time.  (You'll probably want your keyframe to use a "Step" function.)
Blessdaily
Blessdaily
Posted 10 Years Ago
Senior Member (330 reputation)Senior Member (330 reputation)Senior Member (330 reputation)Senior Member (330 reputation)Senior Member (330 reputation)Senior Member (330 reputation)Senior Member (330 reputation)Senior Member (330 reputation)Senior Member (330 reputation)
Last Active: 7 Years Ago
Posts: 3, Visits: 34
Hi im a newb so please bare with me, i hope someone can help
I'm trying to make a short animation with  text , and then later i want some more text to appear underneath it ..
for storytelling and that sort of thing.
maybe there is a better way to do this. but this is how i tried to do it..
i made two pictures (.png),
i figured.. i could use these pictures as textures on a floor object in iclone6 and just change the texture  later in the time line..
the first picture has the first line of text, and then a second picture has the rest of the text .
My problem..
 Every time i try to change the texture  to the second picture,  it changes the first texture as well. even though i am later in the timeline
the diffuse option in texture settings is hightlighted in green, its my understanding if any area in iclone6 is highlighted in green i can animate it?
but its not animating my changes? so i must be doin something wrong ...is there anyone who can help me?
