3doutlaw
3doutlaw
Visits: 193
I am wondering if there is a way to get a Lens Flare in iClone? A google search turns up a prop maybe, but I was hoping to do something like I did in Carrara in this video for spaceship engines, around the 22 second mark:
Yes. Check out "HDR" effect. I can't remember, but it might be under the "Atmosphere" tab. Go to the help page, and search for "HDR." http://manual.reallusion.com/iclone_6/enu/pro_6.0/default.html
3doutlaw
3doutlaw
Visits: 193
Nice that should work, thanks!
Last Active: 7 hours ago
Posts: 15.7K,
Visits: 30.5K
Unfortunately, there is a known bug where HDR doesn't work properly for some cards (seems to be the 900 series of NVidia, among others). I've been waiting for a solution since it was first reported.
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
From your Demo clip it appears a Glow Map might be more appropriate to control the light emitted. The Glow can be controlled with about 5 keys.. then you can copy and paste those on the Material Line if you want a Flash, or space out the keys to maintain a Glow period. Sample Video The highlighted shortcut (above) gives you a simple glow map that fits the 3D Block default Cylinder_001, but also fits those with the same of approximate UV as that Cylinder.
SKYPE ID: rc.650
9 Years Ago by
Cricky
