cynsegura
cynsegura
Visits: 1.1K
Is it possible with character creator, create a character from a photo? I believe the reply is no.. But I will be happy to hear if someone has tricks or something to help! Thanks
Last Active: 6 hours ago
Visits: 62.1K
Looking at the UV and diffuse for the head, I'd say "get photoshoppin'!". Some will say adjust the UV to match the photo, but that is probably more than should be done here. Start by matching your photo to the existing UV, load it on the face as a decal in CC, and morph the head to resemble the photo's head shape. UV and diffuse from CC (low resolution example, not for use ) Couple important things: You may want to only do defining things, like moles and eyebrows. Different wrinkles than CC has might be good. Remove as much "face shine" from your photo as possible, as you really only want lighting from how you set it in iClone. Notice how "flat" the diffuse image is. This is important for good results.
AverageJoe
AverageJoe
Last Active: 8 Months Ago
Posts: 2.4K,
Visits: 10.1K
Hopefully, RL will be adding the feature back in. Looking at that UV and Diffuse Rampa shows as an example is far more work than I want to do to get a photo onto a character...
Last Active: 11 hours ago
Posts: 15.8K,
Visits: 31.1K
Face creation from a photo using CC has been announced for Q4. This will probably mean around Xmas.
JimmyB7
JimmyB7
Visits: 3.2K
This process looks promising. Sorry if it has already been posted. 3Dtest: iClone 6/ CC face texture and normal mapping tutorial
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU, ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6, ASUS PA329Q 32" 4K/UHD IPS Monitor.
The Mythical Dragon
The Mythical Dragon
Posts: 1.1K,
Visits: 4.7K
AverageJoe
AverageJoe
Posts: 2.4K,
Visits: 10.1K
The part where you overlay the image on top of the model to tweak the morphs... How'd you do that? Is that inside the CC somewhere?
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 29.0K
Awsome result Jimmy!!!
JimmyB7
JimmyB7
Visits: 3.2K
My claim to fame here is only discovering this tutorial from 3Dtest on YouTube. The overlay software he describes is in the 3Dtest video, and can be downloaded from http://imageoverlayutility.bitbucket.org/
I tried it, and it works as he describes.
9 Years Ago by
JimmyB7
Visits: 62.1K
JimmyB7 (9/30/2015)
Thanks for that! That's a fair bit easier than how I was setting up before. I had made default scene with the overlay plain and image on it. This is so much easier! If you want to stay in the CC environment, you can do the face as a decal.
