@ Soyasu - thanks for responding! :)
rampa (9/23/2015)
Bellatrix (9/23/2015)
IBL bug identified since 6.0.
Hopefully can be fixed before 6.3.
IBL softness custom setting failed to be saved with custom Projects.
When custom project re-opens softness always at zero.
IBL softness setting also revert to zero for every new IBL textures loaded.
All others, HDR/AO/Shadows etc custom settings no such issue and behave as expected.
Thank you.
Oh, and Avatar Toolkit is on my potential to-buy list but only if it works with CC and GoZ!
So good to know its being improved... :)
Cheers
It bakes a new IBL image with the project, and resets the slider. It also bakes any of the IBL color adjustments. The strength, of course, cannot be baked, as it is not part of the image, but rather a program setting.
No by default it DOESN'T bake new IBL image with projects. Unless user chooses to EMBED TEXTURE.
This means by default there are only 2 IBL settings: Softness, Strength.
I like to keep it simple. No activation of color adjustment etc.
Strength adjustment keeps when project saved. Therefore SO SHOULD Softness.It's a "oops forgot to
keep it consistent" thing. Nothing new.
So by default/ un-embedded, everything loads with excess specularity.
An annoyance. No big deal.
I just have to waste 4 clicks EVERYTIME I launch iClone/ default custom scene.
Click Visual tab. Scroll down down. Increase softness. Click Scene tab.
Of course I could embed texture - which actually bakes the softness.
But IClone is over-zealous with file shrinking.
No way to calibrate compression rate. Kid glove as usual...
I dream the day iClone arrives at the space age capability of Macro ;)
>>> Indie Generalist modeler-rigger-animator <<< Hardware: AlienWare i7-HK 32G GTX1080 2T-SSDs BenqSW320 Wacom-Intuous 3Dconnexion ||| Software: IC6 Pipeline - CTA3 Pipeline - ATK2 - Indigo ||| Zbrush4R8. Blender 2.79. DazStudio 4.9. Carrara. Poser. Octane.
