OFFICIAL iClone 6.2 Issues Thread
Posted By Peter (RL) 11 Years Ago
5
6
7
8
9
10
11
CaseClosed
CaseClosed
Posted 11 Years Ago
Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)Distinguished Member (3.4K reputation)
Posts: 344, Visits: 781
CaseClosed (9/21/2015)
POINT LIGHT -- WILL NOT cast shadows onto a PLANE  - even if that plane is made into a TERRAIN
DIRECTIONAL LIGHT --  WILL cast shadows onto a PLANE
They both cast shadows onto a TERRAIN brought in from templates.
Okay, I'm creating interior scenes now, and I put a point light in the scene. Why does the furniture in the scene NOT cast shadows from the Point Light?
Has this been discussed? Resolved? Work around created? Thanks!!!
mark
mark
Posted 11 Years Ago
Posts: 4.9K, Visits: 16.7K
As far as I know Point Lights have never cast shadows in iClone. Only Directional and Spotlights cast shadows in iClone.
PROMO-BACK2
Posted 11 Years Ago
Posts: 8.2K, Visits: 26.5K
CaseClosed (10/10/2015)
Not a bug.  It's by design.
Personally, I tend to view it as a flawed design, but it's documented that way in the manual.
(Maybe they changed the documentation to match the bug?  ;) )
https://forum.reallusion.com/uploads/images/dd6b084d-c9ac-4d24-8964-3766.jpg
P.S.
Hi Mark.
I was pretty sure the lack of shadows from Point Lights was as-planned.
Looks like you posted (correctly) while I was looking for documentation to back me (us) up.
Posted 11 Years Ago
Posts: 8.2K, Visits: 62.6K
It's actually almost always better to use spotlights if you can. Because point lights do not cast shadows, they show right through surfaces, like a character's cheek. Surfaces do not stop light in iClone, shadows do. So run your shadows at 100% as well, otherwise they "leak". ;)
CaseClosed
CaseClosed
Posted 11 Years Ago
rampa (10/10/2015)
Thank you everyone!  Spotlight it is.
rampa, what's that about leaking shadows?  if the opacity on the project visual shadow setting is less than 100%, the shadows leak?  I think 100% will work for us, but I'm curious about the leaking. Thanks.
Posted 11 Years Ago
Because it's the shadow stopping the light, rather than the surface, a shadow setting of less than 100% is letting some light through. If the shadows seem to dark at 100%, then adjust the ambient light to something brighter. I run my ambient at 128 gray, or even white. You then need to turn down the brightness of your scene lights. You usually end up with a much better lit scene by doing this though. It gets rid of that awful dark fringing and looks a lot more like real lighting. Set your shadow bias to -1 or -2 to make sure that there is shadow under character clothing and other things really close to the surface they should be casting shadows on.
alternately, you can set the ambient to black and enable IBL, and set it to full strength. This has a slightly different effect, and you might find it pleasing. An added benefit to doing it this way is that you can use all the slider controls for the IBL to see brightness and color changes as you change them, rather than when you hit OK on the light panel. It's super cool! ;)
CaseClosed
CaseClosed
Posted 11 Years Ago
Thank you my friend :)
Agonos
Agonos
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 1.1K, Visits: 3.1K
Another patch this day. It would be good I think, at the end of the installation of a patch, a message indicating the changes appear.
CaseClosed
CaseClosed
Posted 11 Years Ago
Agonos (10/12/2015)
Agreed
Posted 11 Years Ago
Posts: 23.1K, Visits: 36.6K
iClone 6.21 has now been released so we will be closing this thread. Many thanks for all your feedback.
Please post any remaining bugs, glitches or other strange behaviour in the new iClone 6.21 issues thread below.
https://forum.reallusion.com/257571/OFFICIAL-iClone-621-Issues-Thread
Thanks. :)
5
6
7
8
9
10
11
