Posts: 23.1K,
Visits: 36.6K
Thanks for supplying the link. This is an old thread referring to editing spring SPX files in 3DXchange. You should not need to do this with the default Natalie CC character or those you send over from Character Creator. These should work just by turning ON Spring effects for the two left and right rib bones. It may be that you have outdated content in your iClone library causing Spring not to work. This can happen if you only patch iClone itself and don't install the updated resource pack. I would advise uninstalling iClone 6 and then perform a clean install of the latest full version including the latest resource pack. Then check again to see if Spring effects work for CC Natalie. Note: Spring effects don't work with the non-standard G6 Heidi character without further editing in 3DXchange but Natalie and other CC characters should work fine.
Last Active: 9 Years Ago
Visits: 61
For the past couple days I've been uninstalling ic6, reinstalling with resource pack and the patch for 6.5. Still not working
Improvise, Adapt, Overcome! - Gunnery Sergeant Thomas Highway, USMC Heartbreak Ridge
Visits: 61
Finally figured out my problem. It seems the spring effects can't be seen in quick mode. Only in high, medium, and custom modes.
