Dedicate more memory to iClone
Posted By RussellStudios 11 Years Ago
3
4
RussellStudios
RussellStudios
Posted 11 Years Ago
Veteran Member (539 reputation)Veteran Member (539 reputation)Veteran Member (539 reputation)Veteran Member (539 reputation)Veteran Member (539 reputation)Veteran Member (539 reputation)Veteran Member (539 reputation)Veteran Member (539 reputation)Veteran Member (539 reputation)
Last Active: 9 Years Ago
Posts: 75, Visits: 304
How can I dedicate more memory to my iClone program on my computer?
I keep getting a Free Disc Space on Disc C is insufficient iClone may not run smoothly
I have a program that's 661944KB
54000 frames
Avatars                 7
Props                  51
Tree                      0
Grass Group         0
Particle Emitter     0
Light                     4
Camera               17
Path                      4
Video                   11
planetstardragon
planetstardragon
Posted 11 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Posts: 11.5K, Visits: 46.0K
that sounds like a security issue -   have you tried running iclone as an administrator ?   maybe your system is isolating iclone ?
"To define Tao is to defile it" - Lao Tzu
RussellStudios
RussellStudios
Posted 11 Years Ago
Nope still have the same problem!
planetstardragon
planetstardragon
Posted 11 Years Ago
hrmm,   well from a purely analytical point -  if you have the space, and iclone is not accessing it,  iclone is not self restricting,  so you have to find what is restricting iclone from recognizing the rest of your drive.      My first reaction is security because that's how some anti virus,  or firewall programs work -  they isolate the unverified program for damage control -  otherwise other possible causes are a damaged drive,  defective install,  and I'm guessing that you would have known if that was the issue by the way your system performs with other software.
I'd say to disable your anti-virus, custom firewall  ( as this is something a firewall like comodo might do for security ),  but that may not help if your av has iclone in some sort of limited / quarantine state as more often than not,  shutting down an av just disables it's monitoring state,  but not necessarily disables files the av placed in quarantine.
prabhatM
prabhatM
Posted 11 Years Ago
Last Active: 6 Years Ago
Posts: 1.8K, Visits: 8.1K
This is a known issue.
I raised and documented this 18 months back while testing ICLONE.
Time and again it has come up with other users.
On my 2 TB hdd, it showed a message INSUFFICIENT SPACE.
I could never figure out on what basis a programmer could assign such a message in the programme !
prabhatM
prabhatM
Posted 11 Years Ago
Check this again by reducing the number of frames to a little less than 50000.
I think that is where it maxes out.
planetstardragon
planetstardragon
Posted 11 Years Ago
ya,  or that ...i get that when i try to render large uncompressed avi files, files are not allowed over a certain size.....i render small files like 200 frames max to mp4 - it's so much easier to edit, manage and store than insanely large avi files.
so i guess that would be a self restriction.
RussellStudios
RussellStudios
Posted 11 Years Ago
Yeah, I reduced the number of video files already to a lower grade, also took 5 videos that played next to each other and turned it into 1 video instead, getting rid of 15 in total.
Still shows a large file as if I did nothing and still have just as many videos.
I even had some videos that played in a loop creating more videos on the time line, but turned them into 1 long playing video instead reliving more videos.
I will try to cut the frames back to 50000 but don't have much hope in it's success!
But again you ever know.
I will give it a try and get back to you!
I also have a Norton Security system and have viewed it's details already, it doesn't appear to be the problem.
Thanks for the input   :~()
hattori kun
hattori kun
Posted 11 Years Ago
Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)
Posts: 868, Visits: 4.1K
Try changing the temp folder in Preference.
I have mine at D:\Temp\Iclonetemp\
RussellStudios
RussellStudios
Posted 11 Years Ago
I do not have a drive D
Only a Drive C
I suppose I could move the folder to an external hard drive, say a 2 TB drive.
But I don't see how that would make the program work any faster or lag just because the folder was moved!
3
4
