Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
CrazyTalk 7 is a very popular program but it is also quite simple to use which is why you will not find so much discussion here. iClone and CrazyTalk Animator on the other hand are more complex programs so you will find these forums a lot busier as the learning curve is steeper and more help is generally required. However if you have any questions about CrazyTalk 7 please do ask away. :)
GSDlady
GSDlady
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 16
OK, Thanks for your response. I thought the fourm was more for tech support as a lot of company's do this. There does not seem to be a lot of user interaction.
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
In the Pro version you can add multiple voice tracks along the timeline. In the Standard version you can only add one voice track which can be up to 15 minutes in length. Regarding your question about the forum being monitored, yes it is (hence my reply here) but it is primarily intended for user to user discussion. If you need Technical Support, please use the link below to submit a ticket. We will then get back to you normally within 48 hours. :)http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
GSDlady
GSDlady
Posted 11 Years Ago
Visits: 16
Can I record twice? What I would like to do is have a recording at the beginning, an action and motion and then have them talk again. Is this possible? I've also noticed this forum does not appear to be monitored as I do not see the developers answering questions.
