planetstardragon
planetstardragon
Posted 11 Years Ago
Posts: 11.5K,
Visits: 46.0K
since iclone does not export 360 natively, you will have to approach it manually. - create 2 (or more ) cameras facing opposite each other, attach both cameras to a dummy object ...animate the dummy object to spin 360 degrees. - render the 2 separate camera views to video, then stitch the video clips together in a loop. http://www.kolor.com/360-videos/
GSSEV3D
GSSEV3D
Posted 11 Years Ago
Visits: 744
Hi, did you get indigo to do a 360 render?, Not sure if you can adapt the camera for this or use a reflective spherical surface to capture all of the scene. I have put in the wish list for Iclone to output 360 degrees images and video.
emreboz34
emreboz34
Posted 11 Years Ago
Last Active: 6 Years Ago
Visits: 174
answer ?
emreboz34
emreboz34
Posted 11 Years Ago
Visits: 174
hello everyone. I'm curious Something . How to make a 360 degree rendering with indigo? for example; Iclone6 + Indigo rendering = 360 degrees movie: D I want to make it ;)
