Clarifying Key Frames
Posted By Lord Ashes 10 Years Ago
Lord Ashes
Lord Ashes
Posted 10 Years Ago
Posts: 1.3K, Visits: 1.6K
Like many other software (including DAZ), I find that the Key Frame information is not very specific. For example, in iClone if you create a key frame for an object position adjustment, rotation adjustment or scale adjustment then it places a key frame indicator on the Transform track.
How can I tell which of these properties have been keyed? Or does a key frame automatically key all properties (i.e. all position, all rotation and all scaling values)?
The problem seems to get compounded when working with objects that have multiple parts (including Avatars) because you can modify each part (bone) individually but the tracks don't break down to individual bones (as far as I can see). This means, for example, that on an Avatar if I move a pinky finger I am going to get a key frame indicator in the Transform track but how do I know what was adjusted at that frame?
If a key frame just stores all values (all position, all rotation and all scaling) then this is very impractical because, especially in a multi-part object, you want to key frame some properties but not all. If key frame stores just some values then it does not seem to be obvious which ones were stored. Unless there is some component of iClone that I have not discovered.
Also when manipulating bones via Edit Animation Layer, is there a way to enter values for the bone position, rotation and scaling as opposed to adjusting them using the sliders? In some cases entering in a value (e.g. to make same adjustment to multiple parts the same) is preferred to using W/E GUI interface.
I am going to say it because I fee that it should be noted: In my opinion, when it comes to handling key frames, Anim8or (a free 3D editing, 3D modeling, 3D animating and scene rendering software that consists of a single EXE that is less than 5MB) wins over both iClone and DAZ hands down. In Anim8or the key frames go down to the bone property but only appear as a track if there is at least one key frame, for that property, set someone in the scene. So, for example, if you have an object that is made of 3 parts and you key frame X and Y position of Part 2 of that object it would create two tracks ("Object Part 2 Position X" and "Object Part 2 Position Y"). If the Z position, rotations and scaling was not used for Object Part 2 anywhere in the scene then they would not be shown in the tracks. These tracks where presented in a hierarchy with higher components summarizing its children. So, for example, if Object Part 2 Position X and Object Part 2 Position Y were set, there would be a key frame marker on each of their tracks but also a key frame marker for Object Part 2 and for Object. Thus by closing the hierarchy you can immediately see which Objects were key framed at any time (similar to what iClone and DAZ show) but by opening the hierarchy it is possible to see what parts in the Object were key framed and opening the hierarchy even more showed you exactly what properties where key framed.
In my opinion this gave maximum flexibility (i.e. any property could be key framed without affecting other properties) with easy and proper identification of what properties have been keyed at each key frame.
BTW, Anim8or might be a oldie with a dated looking GUI and a little bit of a learning curve (although the manual is fairly short) but it amazes me what the programmers were able to cram into the software. Sure, it does not come with any content but it supports 3DS, LWO and OBJ imports (as well as its own AN8 format which is very human readable) out of the box and, as I said, has everything from creating 3D models (you can go down to point by point editing), boning the models, creating animation sequences for the models and building and rendering scenes. All of that comes in a single EXE file (no install necessary) and within 5MB. I still you it over modern editors (like DAZ's Hexagon) to this day. One of the only reasons why I don't use it for rendering is that it does not do a proper job of handling colors correctly when I import things like DAZ characters. Like I said, the program has a lot of features that big company software (like iClone and DAZ) are only catching up to. And yes, before everyone flames me, there are many features that iClone has (or even DAZ has) that Anim8or, obviously, does not...but that does not mean we can't learn from it.
