Error on resolution support
Posted By Midou123 10 Years Ago
Ibis Fernandez
Ibis Fernandez
Posted 10 Years Ago
Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)Distinguished Member (16.6K reputation)
Last Active: 11 Months Ago
Posts: 1.2K, Visits: 4.3K
The cta UI is not very flexible. Even if you could get it to work you still wouldnt be able to work with it. For example, the panels have the system buttons on top (close/minimize/expand) and the actual function buttons or selection tabs at the bottom.
You can't resize below a set minimum size so it means that on a small screen all you can do is open and close panels.
If you can get a second monitor and attach it, you might be able to get it to run. But it may not run well due to your other specs.
https://forum.reallusion.com/uploads/images/ad51c90b-00a8-459d-8ca4-2136.gif
Ibis Fernandez   |   (available for hire)
Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer
Author of Flash Animation and Cartooning: A Creative Guide
>>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
Posted 10 Years Ago
Posts: 23.1K, Visits: 36.6K
Midou123 (3/6/2015)
Thanks for replying!
Yes am using a netbook
actually not a normal netbook because i runned far cry2 gta san andreas and much modern games on it and some are without lag!
here is my specs from dxdiag :
you said as much as possible :P
Thanks for supplying your dxdiag.txt.
Unfortunately your computer does not meet the minimum specifications for CrazyTalk Animator 2.
For example you need 2GB of Ram (4GB recommended) but you only have 1GB. You also need a minimum screen resolution of 1024 x 768 and a video card with 512MB both of which you are lacking.
If you are considering upgrading your computer, then please take a look at the requirements below. You will need to meet the minimum but ideally try to get a system that meets the recommended specs.
Midou123
Midou123
Posted 10 Years Ago
Junior Member (192 reputation)Junior Member (192 reputation)Junior Member (192 reputation)Junior Member (192 reputation)Junior Member (192 reputation)Junior Member (192 reputation)Junior Member (192 reputation)Junior Member (192 reputation)Junior Member (192 reputation)
Last Active: 10 Years Ago
Posts: 2, Visits: 16
System Information
Time of this report: 3/6/2015, 23:15:02
Machine name: ASUS-PC
Operating System: Windows 7 Édition Intégrale 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer INC.
System Model: 1015BX
BIOS: BIOS Date: 06/30/11 15:49:40 Ver: 04.06.04
Processor: n/a
Memory: 1024MB RAM
Available OS Memory: 748MB RAM
Page File: 1083MB used, 1709MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon HD 6250 Graphics
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x9804)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9804&SUBSYS_84A41043&REV_00
Display Memory: 364 MB
Dedicated Memory: 246 MB
Shared Memory: 118 MB
Current Mode: 1024 x 600 (32 bit) (60Hz)
Monitor Name: Moniteur Plug-and-Play générique
Monitor Model: unknown
Monitor Id: IVO03F4
Native Mode: 1024 x 600(p) (60.000Hz)
Output Type: Internal
Driver Name: aticfx32.dll,aticfx32.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiumdva.cap
Driver File Version: 8.17.0010.1083 (English)
Driver Version: 8.863.2.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/21/2011 10:14:26, 688128 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-DB44-11CF-C877-AEA4BEC2C535}
Vendor ID: 0x1002
Device ID: 0x9804
SubSys ID: 0x84A41043
Revision ID: 0x0000
Driver Strong Name: oem4.inf:ATI.Mfg.NTx86.6.1:ati2mtag_Wrestler:8.863.2.0:pci\ven_1002&dev_9804&subsys_84a41043
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Haut-parleurs (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_10438437&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHDA.sys
Driver Version: 6.00.0001.6293 (English)
WHQL Logo'd: Yes
Date and Size: 1/18/2011 19:12:34, 3378984 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Souris
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Clavier
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1A2C, 0x0C23
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Concentrateur USB racine
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/14/2009 00:52:09, 258560 bytes
| Driver: usbd.sys, 7/14/2009 00:51:05, 5888 bytes
Gameport Devices
PS/2 Devices
+ Clavier standard PS/2
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/14/2009 00:11:24, 80896 bytes
| Driver: kbdclass.sys, 7/14/2009 02:20:36, 42576 bytes
+ Périphérique clavier PIH
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 7/14/2009 00:45:09, 28160 bytes
+ Pilote clavier de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Souris compatible PS/2
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 7/14/2009 02:20:44, 41552 bytes
+ Souris HID
| Vendor/Product ID: 0x15D9, 0x0A4D
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 00:45:08, 26112 bytes
+ Pilote souris de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/14/2009 02:19:10, 51776 bytes
| Driver: sermouse.sys, 7/14/2009 00:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1.1 GB
Total Space: 102.4 GB
File System: NTFS
Model: WDC WD3200BPVT-80ZEST0 ATA Device
Drive: D:
Free Space: 3.2 GB
Total Space: 187.5 GB
File System: NTFS
Drive: E:
Model: DTSOFT Virtual CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/14/2009 00:11:26, 108544 bytes
sorry because its long it has a detailed specs of everything even booting ↑↑↑↑↑
Posted 10 Years Ago
Are you using a Netbook or Tablet because that kind of resolution is very low for a full Laptop or Desktop. If it is a Netbook then it is unlikely it will run CrazyTalk Animator anyway regardless of screen resolution.
Please post your full system specs, including graphics card. This will make it easier to determine if your computer is compatible with CTA2.
Midou123
Midou123
Posted 10 Years Ago
[font=Courier New]Okay,I just saw this crazytalk animator 2 and i found awsome how that 3d in 2d! so i tried to download and install it after everything done it says The Resolution is not Supported... i know all what that mean i have 1024x600 and it just need 1024x768 so please help me i used fake resolution apps and didnt work can you give me a patch or an exe with removed resolution detecting cause i really want to try you will help a lot of people if you did that [/font]
[size=7]THANKS![/size]
Sorry,cause am new!
