mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
The price is the only plantfactory repproche I would do. The EULA is very restrictive.I bought the studio version when it was on a Beta pre-order (360$) and we have had to wait one year !! It's not a "mature" soft for export to other 3D software now. It has a solid integration with Vue.
propose
propose
Posted 11 Years Ago
Visits: 1.2K
I guess I'll stick with Plant Studio. More in my budget. I checked out SpeedTree tho..What a price:w00t:
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
@prabhatM Yes you can modify existing Plantfactory trees :  And you can make anything from scratch:   And there is lot of easy tut here: http://www.geekatplay.com/dtpf.phpThere will be an update in the first quarter of 2015 . especially for having quad polygons instead triangles. In the "game resolution" the trees are not so good for the price.
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Last Active: 4 Months Ago
Posts: 2.5K,
Visits: 19.4K
yes but they are terribly high poly and to get wind and rustle you need to merge with the dummy bone and use expression editor to animate them. So avatars not props if rustling.
propose
propose
Posted 11 Years Ago
Visits: 1.2K
Thanks for the replys. @ Wendy Have you tried Carrara trees in iClone? just curious if that's an option.
prabhatM
prabhatM
Posted 11 Years Ago
Last Active: 6 Years Ago
Posts: 1.8K,
Visits: 8.1K
mtakerkart (2/24/2015)
I use The Plantfactory from e-onsoftware to make my own plants and export it as fbx for wind motion. Is it possible to EDIT the texture of leaf and trunk in PlantFactory?
prabhatM
prabhatM
Posted 11 Years Ago
Posts: 1.8K,
Visits: 8.1K
I use The Plantfactory from e-onsoftware to make my own plants and export it as fbx for wind motion. Is it possible to EDIT the texture of leaf and bark in PlantFactory?
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
I sent a request the 26th 2014 to reallusion after buying the Speedtree pack , if they may be give the possibility to export from speedtree with an export plugin like UDK or Unity. I had no answer. I use The Plantfactory from e-onsoftware to make my own plants and export it as fbx for wind motion. Speedtree can export fbx too. You need 3Dxchange to import in Iclone. The idea is to make trees not over 12 meg for improving play in realtime.
wendyluvscatz
wendyluvscatz
Posted 11 Years Ago
Posts: 2.5K,
Visits: 19.4K
no the iClone trees are made by a company for iClone and are proprietary to it. The same one that makes speedtrees, iC6 might enable you to buy a speedtree plugin one day. You can import them as props of course
propose
propose
Posted 11 Years Ago
Visits: 1.2K
I have a ton of plants from poser and Daz. How can I convert them to iTree? or is that even possible?
