hattori kun
hattori kun
Posted 11 Years Ago
Visits: 4.1K
mtakerkart (2/1/2015) -Because the render is based on 30 fps and the project in 60fps , a one frame muzzle flash for exemple , is not rendered if it lights on on impaired frame.
Btw this issue is really problematic for me as well. :D I noticed this immediately while learning Iclone https://forum.reallusion.com/FindPost220535.aspxIclone renders only half of whatever is set on the project setting length. So the timeline in Iclone is not really an exact reference for animating. Probably good to stick to even numbers because most probably odd number frames will be ommited in rendering to images like your muzzle flash.
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
Thank you very much for your comments!! :)
@ hattori kun
There are 3 reading level for the end : -The warior never die -The robot make the warior more efficient at each die -To die for both the warior have to kill the robot first
hattori kun
hattori kun
Posted 11 Years Ago
Visits: 4.1K
Very cool work! I didn't understand the ending though.
dwacon
dwacon
Posted 11 Years Ago
Last Active: 7 Years Ago
Visits: 639
Excellent work. iC6 is a bit frustrating... but as new releases come out, trust it will become much easier.
Atomic Skeletons [url=http://amzn.to/2zZ3md9]Queer Steer[/url] Black Larry DavidGalactic BlitzBirthday Movie
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posted 11 Years Ago
Posts: 1.2K,
Visits: 7.2K
Very nice, I like it. I had to watch it until the end :)
-- guy rabiller | GOETZIWOOD STUDIOS "N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
james_muia
james_muia
Posted 11 Years Ago
Visits: 1.3K
Fantastic film, great job! I really enjoyed watching it. Just keep in mind, Iclone is not visual effects software. Muzzle flashes, smoke, fire, flares, should all be done in after effects or a visual effects editor! Edit: Rain, snow and weather effects makes more sense to use Iclone due to having so many angles and continuity but a lot of the effects just aren't great "Quality" so hence better effects in using AE or some other program for as much as you can.
IMDB: James Muia Aviticus Dragon on YouTube
Computer Specs: Intel® Core™ i7-7820X Processor (8x 4.30GHz/11MB L3 Cache) Corsair Hydro Series H115i 280mm Liquid CPU CoolerASUS ROG STRIX X299-E Gaming Motherboard 32 GB DDR4-3200 GSKILL Ripjaws V Memory NVIDIA GeForce GTX 1080 Ti - 11GB - EVGA FTW3
mark
Posts: 4.9K,
Visits: 16.7K
For me iClone has always been about figuring out the workarounds. Excellent animation!!!:D
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
@rampa
Thank you for your tut , very useful for me . As I said, I have to figure out exactly the moves sequence for collecting clips whithout any props or scene before doing anything...
@Dragon Thanks a lot !
My next project will be with my own characters ,Neuron perception mocap and lot of dialogues...:P
The Mythical Dragon
The Mythical Dragon
Posted 11 Years Ago
Posts: 1.1K,
Visits: 4.7K
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
Thank very much for your comments!! :) @thedirector1974 I made this for my camera hand ! :) and use the facial puppeter....
