To move or copy your content to Crazytalk 6 you can do one of the following:
1.. Use The Content Wizard to do all the hard work for you. (Recommended)
http://www.reallusion.com/crazytalk/crazytalk_tool.asp2.. Use Windows Explorer to copy over manually from your CT5 folders to the CT6 folders.
3.. Install the packs again. You should be given the option to install to CT6 this time.
This is what I was told - And it worked fine!
Cathy :hehe:
Just click on the graphic to go there.
