My first 3D-Video Test with iClone 6
Posted By Odie_Schnitzel 9 Years Ago
Odie_Schnitzel
Odie_Schnitzel
Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)Veteran Member (673 reputation)
Posts: 24, Visits: 486
It's a pitty, that iClone does not support 3D rendering with Indigo! Nevertheless I decided to set up a new Workflow for me, to be able to produce 3D Clips from now on, well currently with iClone Renderengine, because Indigo is not supported. Hopefully in a upcoming Version?
During the production of the 3D-Clips I found 2 small bugs within iClone 6.01, one you can see imeadatly in the Video(even without a 3D Television) the second is, that within 3D iClone counts every Frame twice! So if you want to produce 100 Frames, you have to go for 200! 100 for the left and 100 for the right eye!BigGrin
So, if you are able to see the Videos in 3D you can find mine here:
http://youtu.be/yNxHW5bsCpY
Comments as always appreciated! Wink
