reduce swing on arms during 'walk forward'
Posted By Darren01 9 Years Ago
Darren01
Darren01
Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)
Posts: 639, Visits: 4.0K
hi
I'm hoping there is an easy fix to this
I've used the 'move/walk forward' function on my avatar.
Works fine, but the avatar looks like she's power walking - far too much swing on her arms!
I've fiddled with the 'motion modifier' panel, it has lots of adjustments like sway etc, but nothing seems to change the arm swing.
I still want the arms to swing, but reduce it.
Can anyone point me in the right direction ?
thanks
Darren
_________________________________________________________
colour
colour
Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)
Posts: 5.2K, Visits: 8.1K
Gwynne G5 Character's Walk Forward Motion is natural, Darren. No Power Walking Wink
IMO, simplest Fix would be to Export Gwynne's Persona to your Deskop & Import that Persona into your Character, if it's a  G5 Character.
If not a G5 Character, see Screenshot for Editing Arms Motion Layer.
Screenshot
9 Years Ago by colour
thebiz.movies
thebiz.movies
Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)Distinguished Member (13.2K reputation)
Posts: 2.0K, Visits: 41.2K
If your using the motion puppet (which I think you are because of your mention of the motion modifiers) try to reduce the exaggeration.
Darren01
Darren01
thanks for the replies guys
Colour - sorry forgot to mention I'm using a G3 character.
With the 'edit motion' that you demonstrate in your screen shot - that would mean I would have to key frame the arm swing manually wouldn't it ? (which would be a fair bit of work) Or is there just a way I can just limit the effect/travel of the automatic swing motion ?
thebiz - no I'm not using the motion puppet. I've just right clicked the avatar and chose the 'walk forward' motion. I don't know much about the modify motion panel, I just tried it as an option when I right clicked the motion in the time line. But it doesn't seem to apply to preset motions ie 'walk forward'
9 Years Ago by Darren01
colour
colour
"Darren01 (1/20/2015)
thebiz - no I'm not using the motion puppet. I've just right clicked the avatar and chose the 'walk forward' motion. I don't know much about the modify motion panel, I just tried it as an option when I right clicked the motion in the time line. But it doesn't seem to apply to preset motions ie 'walk forward'"
"Colour - sorry forgot to mention I'm using a G3 character."
Which one, Darren?
If I have it, I'll play-around with it.
In the meantime, here's a very quick Screenshot., Follow the red underlining.
1) Violet G3
2) Drag Timescale Scrubber to Walk Forward left hand arm full extent.
3) Edit Motion Layer; Rotate Left Arm down a bit.
4) Repeat for Right Arm.
5) Play-back. Arms don't "Power Walk".
6) Collect Clip (If you want to) As new Walk Forward Motion  Haven't tested that yet. But should work .
7) You can use the Time Warp Curve Editor, to slow Motions-down, reducing the Power Walk. (More on that, if you want).
Screenshot:
Darren01
Darren01
thanks again Colour for the assistance
The G3 base I'm using is Violet (clonecloth version) Btw, I have spring effects turned on, to make the movement a little more realistic. Does that effect things in regards to the swinging of the arms ?
Before I saw your reply, I got a bit impatient.... Tongue I ended up doing it the long way adjusting (motion editor) the position of both arms at the end of their swing for the duration of the walk - fortunately it was a relatively short walk! It worked, but obviously not exactly an efficient way of doing things.
But this character will be doing some more walking in this movie, so I'd like to try your suggested method. So have I got this right...
I adjust the limit of travel of both arms on one walk cycle. Collect the clip and use it as the walk motion instead of the standard walk motion associated with the avatar (ie right click 'walk forward) ? If this is what you are suggesting, then obviously I'd also need to move the avatar/transform or it will just walk in the one spot. Correct ?
colour
colour
IMO:
1) Yes
2) Collect Clip should add new Walk Forward Motion to Character Perform Command. Name it Walk Forward 2, in Collect Clip save Pop-up.
Darren01
Darren01
ah ok, that's good
I'm not overly familiar with the collect clip function. I didn't know it gets added to the perform command. Very handy. I will have to start using it more
thanks again, you've been very helpful as usual!
planetstardragon
planetstardragon
Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)Distinguished Member (23.3K reputation)
Posts: 11.5K, Visits: 45.9K
i'd use the motion puppet myself .....if the feet and everything else are right ....then I'd just erase the motions on the arms ...load a standard walk cycle, and just record new arm motions.
I'm sure there are other ways, but I'm even more sure they are more tedious than just recording new arm motions and calling it a day lol Tongue
Darren01
Darren01
just a bit of an update on this one - tip for people like me Smile
After some experimentation and help above from colour, I found if you are using a G3 character, I found the easiest way was just to create a path and use Gwyn's G5 walk motion rather than trying to modify the inbuilt 'move forward' function.
