Choose the Intel Indeo Video 4.5 codec to export an avi with alpha transparency. There is supposed to be a HuffyUV codec and a supposedly higher quality lossless codec named Lagarith that does the same but I don't have either installed on this machine to try it - yet. I think I'll go get them while I'm thinking of it. I tried the Indeo 4.5 codec yesterday on a project and it worked great when working with the avi output from CT5 beta in Premiere Elements 3.0.
Update:
I just tried 4 codecs with CT Media Studio 4.6. Indeo 4.5 and 5.1 work to output alpha transparency - be sure to set that up in the configuration settings during the save of the avi file.
Then I tried HuffyUV 2.1.1 and Lagarith 1.3.14.0 and both work really well. Here too you need to have the settings correct when saving the avi to use alpha transparency/RGBA, whatever the particular codec configuration setting uses to describe this feature.
I hope this info helps someone in the future even if the original question was posted a month ago.
16 Years Ago by
dtodd
