G3 Files
Posted By Mel H 12 Years Ago
Mel H
Mel H
Posted 12 Years Ago
Posts: 399, Visits: 8.2K
Is there an easy way of converting G3 files into Iclone 6
Carmello Holden
Posted 12 Years Ago
Last Active: 3 Weeks Ago
Posts: 15.8K, Visits: 31.4K
I assume these are VNS files? What I have done is load them in iClone 5 and then save them. If they are iProject files then you should be able to load them directly from what I have found.
Another way to convert is to load them in 3DXchange. There is now an option to make the Target Version iClone 6, whatever that means:
There is no batch process unfortunately...:crying:
rgreenidge
rgreenidge
Posted 12 Years Ago
Posts: 257, Visits: 1.7K
Thanks Animagic I was stuck because I bought a .VNS prop from iClone that I'm thinking of using it if I like the way it looks. But after I loaded it in my iC6 folders with all my other files. The .VNS files donot show up in the iC6 window. So I will convert them as you say in exchange 5. So far every project or item I loaded from the iC5 files into iC6 worked without a hitch, except one time a project went out of audio synch until I re-loaded or re-booted it after doing something to it that messed it up. So far using old stuff has not caused a problem except with some the attached accessories being visible when the main object was set as visible off, and I had to find those accessories individually on the time line and turn off the visibility. I addressed that to Peter and I hope that gets fixed in the next patch. I haven't tried the iC6 avatars and have no need for them until I can create my own faces with them, because I use real people images. I also found if I use the dome light, I would have to change the light source to spotlight, to only light on one side. Loving iC6 so far and It's becoming addictive and what I truly wanted. I'm quite sure some of my objects go back to iC3.
I'm still messing with stuff, and like you said about the FPS outputs, it would be nice if they gave us all the frame options with all their video output formats. Right now to get my Jet engine fan blades to appear that they are rotating, I would have to render that scene in AVI at 20, and than convert that video to mp4 @ 30, and see if it still works. I'm surprised that there are not options for 25 FPS, iClone 6 is used in Europe too.
Home built; ASRock X570 Pro 4, AMD Ryzen 9-5950X CPU, AMD RADEON RX6900XT, 16GB video card, 131GB of RAM.
