iC6 cloth discussion
Posted By wendyluvscatz 12 Years Ago
wendyluvscatz
wendyluvscatz
Posted 12 Years Ago
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Posts: 2.5K, Visits: 19.4K
the latest attempts by me
UV mapping of the cloth seems the most important factor along with one material zone on clothified bit
I set up collision shape (and save the preset) for all the body parts on the Avatar under settings
then in PhysX choose edit weight map and select mostly lowers, uppers are usually a mess, hair is good or on a DAZ figure a cape or skirt if one piece and flatmapped
I use the gradient falloff map for my weightmap which one depending on cloth UV, lowers mostly black on top fading to white below.
a solid pinned one tends to break up too much
I did sideways versions of the two supplied as well, the darkest end being the pinned bit.
adjusting contrast and brightness usually needed but iClone realtime makes this easy in by frame mode.
self collision checked is usually needed too but my cloths will not collide well with each other.
Threaded View
Threaded View
Forum Post iC6 cloth discussion By wendyluvscatz ( 12 Years Ago )
Forum Post I have started playing with this as well, so a thread to share... By animagic ( 12 Years Ago )
Forum Post When it doesn't look real it looks unreal and contrived. Is it good... By rampart ( 12 Years Ago )
Forum Post [quote][b]rampart (12/20/2014)[/b][hr]When it doesn't look real it... By animagic ( 12 Years Ago )
Forum Post yes a lot of my DAZ clothes too many polys most are far too complex... By wendyluvscatz ( 12 Years Ago )
Forum Post Marvelous Designer 2 [url]http://www.marvelousdesigner.com/[/url] ... By rampart ( 12 Years Ago )
Forum Post [quote][b]rampart (12/20/2014)[/b][hr]Marvelous Designer 2... By duchess110 ( 12 Years Ago )
Forum Post [quote][b]duchess110 (12/20/2014)[/b][hr] This is a mesh I did... By prabhatM ( 12 Years Ago )
Forum Post Nice work, Wendy. I'm always fascinated by the clothing, and now soft... By justaviking ( 12 Years Ago )
Forum Post I'm not sure if you can still purchase 2. I did way back the small... By duchess110 ( 12 Years Ago )
Forum Post Duchess it is really cool you are into this. I will certainly be... By rampart ( 12 Years Ago )
Forum Post Sadly I already used up my trial of MD a couple years ago and did not... By wendyluvscatz ( 12 Years Ago )
Forum Post What is nice is that you can take existing clothed IC5 characters and... By animagic ( 12 Years Ago )
Forum Post I have an ancient program (from 2005?) called "Virtual Fashion Pro".... By Rampa ( 12 Years Ago )
Forum Post As I mentioned, I took one of Mike Aparicio's creations to play with... By animagic ( 12 Years Ago )
Forum Post Some existing models seem to work pretty well. Others, Not so much. ... By Rampa ( 12 Years Ago )
Forum Post The head dress is a fairly complicated wrap, so it's hard to know what... By animagic ( 12 Years Ago )
Forum Post One other consideration that crossed my mind: We have the collision... By animagic ( 12 Years Ago )
Forum Post Has anyone tried to keyframe the scaling and/or movement of the... By warlord720 ( 12 Years Ago )
Forum Post There's more tutorial movies going up all the time. Here are two... By Rampa ( 12 Years Ago )
Forum Post Isn't this the same theme as... By Sifr ( 12 Years Ago )
Forum Post [quote][b]Sifr (12/21/2014)[/b][hr]Isn't this the same theme as... By wendyluvscatz ( 12 Years Ago )
Forum Post I hope with new PhysiX engine our content developers would... By prabhatM ( 12 Years Ago )
Forum Post this is the thread I previously posted in before starting this one... By wendyluvscatz ( 12 Years Ago )
Forum Post [quote]I detest when people try to steal others ideas without at the... By vidi ( 12 Years Ago )
Forum Post [quote][b]vidi (12/21/2014)[/b][hr][quote]I detest when people try to... By Sifr ( 12 Years Ago )
Forum Post there were others well before the one you saw but not public and was... By wendyluvscatz ( 12 Years Ago )
Forum Post Myself and another user both simultaneously posted a tutorial on how... By rcsinger29 ( 12 Years Ago )
Forum Post Sifr added that sometimes he is just overbearing. Se let us leave it... By prabhatM ( 12 Years Ago )
Forum Post [url]https://forum.reallusion.com/FindPost211909.aspx[/url] I think I... By wendyluvscatz ( 12 Years Ago )
Forum Post What I like about this thread is that it has a clear title and... By animagic ( 12 Years Ago )
Forum Post [quote][b]animagic (12/22/2014)[/b][hr]What I like about this thread... By justaviking ( 12 Years Ago )
Forum Post and fibermesh hair could not bake or use soft on soft as... By wendyluvscatz ( 12 Years Ago )
Forum Post Good Job on the fiber mesh and also rampa's effort as well. May I... By denclink ( 12 Years Ago )
Forum Post Under the atomic symbol for the cloth modify there are settings for... By Rampa ( 12 Years Ago )
Forum Post [quote][b]rampa (12/22/2014)[/b][hr]Under the atomic symbol for the... By justaviking ( 12 Years Ago )
Forum Post Sidebar question: Friction on hard bodies... value ranges 1 to... By justaviking ( 12 Years Ago )
Forum Post I'm going to bump my question from several days back, about props on... By justaviking ( 12 Years Ago )
Forum Post Ooh! Nice one Wendy! I just finished my hair test as well. Brought... By Rampa ( 12 Years Ago )
Forum Post I used a DAZ fibermesh hair product in store it can work quite well... By wendyluvscatz ( 12 Years Ago )
Forum Post Thanks for the quick reply, I will experiment with some hair, are... By denclink ( 12 Years Ago )
Forum Post Nice job rampa :D I made a test with a older Daz Avatar ..... and... By RB3006 ( 12 Years Ago )
Forum Post That suits Mr. Toad very nicely, Robert! :) The head-banger is... By Rampa ( 12 Years Ago )
Forum Post I've been playing with the new Soft Cloth, I love it but I've got... By pumeco ( 12 Years Ago )
Forum Post Hi pumeco I was also hoping there would be a self mesh but we only... By duchess110 ( 12 Years Ago )
Forum Post [quote][b]duchess110 (12/26/2014)[/b][hr]Hi pumeco I was also... By pumeco ( 12 Years Ago )
Forum Post Another one .... [center] [/center] Robert By RB3006 ( 12 Years Ago )
Forum Post here is my Cloth attempt A not rigged static mesh attached to the... By vidi ( 12 Years Ago )
Forum Post Nice work vidi did you attach to spine2 or did you link to another... By duchess110 ( 12 Years Ago )
Forum Post I have made a custom rig therefore are the Bone names different . I... By vidi ( 12 Years Ago )
Forum Post Thanks for the reply vidi. Understand Cherry has Abdomen - Chest so... By duchess110 ( 12 Years Ago )
Forum Post I got a bit distracted playing with fibermesh hair! that works too... By wendyluvscatz ( 12 Years Ago )
Forum Post Looks cool, Wendy, wouldn't want to weightmap all those strands... By pumeco ( 12 Years Ago )
Forum Post [quote][b]pumeco (12/27/2014)[/b][hr] Looks cool, Wendy, wouldn't... By Sifr ( 12 Years Ago )
Forum Post Flowing Daz (soft cloth) Hairs .... 3.500 Polys [center] [/center]... By RB3006 ( 12 Years Ago )
Forum Post Pumeco, yes LAMH exported as geometry and rigged to the figure not an... By wendyluvscatz ( 12 Years Ago )
Forum Post [b]@Wendy[/b] I just checked it out again, I wish I'd bought that... By pumeco ( 12 Years Ago )
Forum Post UPDATE on my "Table Cloth" experiment. Our esteemed moderator, Peter... By justaviking ( 12 Years Ago )
