R2 Studio
R2 Studio
Posted 11 Years Ago
Visits: 377
Iclone 5's path editing is pretty good-- in fact better than most I have seen but not being able to move path points on local/world axis is my concern: currently you can only move the control point on a local axis which is frustrating. Also: if this and other export files could be sent to an xml format, I can then go in and make broad or even scripted changes to the path points.
Better multiple light configurations: Unity allows massive more amounts of real time generated light sources where iClone is limited to 8... Lumion 4 has similar flexible lighting... this would allow much greater and finer control over the scene's lighting.
No support for Microsoft Kinect Sensor v2 for Windows... not good: I'm going to have to do all my MoCap in MotionBuilder or Unity, then import into iClone... just my wishes, that's all!
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
Not quite sure what limitations you encounter with path editing. IC6 will have an enhanced lighting system with many more lights possible. I understand that improved Mocap is under consideration for IC6 at some later date. No details yet.
