rubbishraider (9/22/2014)
Your so helpful on here, thank you for taking the time to help ... it is much appreciated.
You hit on one thing when you mentioned the volume of each persons voice, because only today, i held my head phones (with microphone) away from me to try to give the allusion of distance? It didn't work lol
It's my pleasure. I get so much help from others, it's always nice (and fun) to be able to help out when I can. Don't worry, you'll be helping others soon enough. More than once I've even seen a newbie help a veteran, simply because he stumbled across a creative way of doing something.
So you like to be overwhelmed? Here's a tip for you... Audacity.
If you haven't already done so, download and install Audacity. It's an excellent, and free, audio recording and editing tool.
I use Audacity for recording my voiceovers. Then I can do noise reduction to get rid of background hum like from my computer fans or the air conditioning or furnace. You can also add echo, or do some pitch changes and lots of cool stuff.
My Audacity workflow for iClone:
- I record a block of dialogue, usually repeating lines multiple times. That's track #1.
- Then I copy it to track #2 and do my noise reduction (I always keep the original so I don't destroy anything).
- Next I copy each line to its own track.
- For each line, I pick out my favorite take, and export it to an MP3 file.
- Then in iClone, I import the mp3 file rather than doing the recording in iClone, and now I have nice, clean audio (with no hiss or hum that appears whenever my characters speak)
For bonus points, I could also put those voice-over lines into my NLE, replacing what I got from iClone, allowing my to further refine things. I did that sometimes because it's hard to keep the volume consistent. I could modify the volume again in Audacity, but then I'd have to put it back into iClone again, ruining any manual lip-syncing I did, and I'd have to re-render my video too.
I also use Audacity to cut and trim some of my music, especially when I use pre-existing music from CDs I've purchased.
So, yeah, at first it sounds like a lot of extra work, and I guess it is, but my last project was a big one and I gradually became convinced that's the best way to work. Any audio in iClone can be considered temporary, used mainly to help you put the animation together.
Necessary? No, not exactly. Desirable? Yes. In the end, that gives you the greatest freedom and control.
You'll need a good naming scheme for all the files. My 40-minute project had nearly 300 mp3 files for dialogue. (I used lots of short clips. Many were one sentence long, so that way it was easy to position them where I wanted.) I also had a lot of music and some sound effects too.
No, you don't have to do all that tomorrow, but you did say you liked being overwhelmed. :P
Anyway... Take it one step at a time. I know I still have miles and miles to go. It's nice to have another traveling companion on the journey.
Desktop (homebuilt) - Windows 10, Ryzen 9 3900x CPU, GTX 1080 GPU (8GB), 32GB RAM, Asus X570 Pro motherboard, 2TB SSD, terabytes of disk space, dual monitors.
Laptop - Windows 10, MSI GS63VR STEALTH-252, 16GB RAM, GTX 1060 (6GB), 256GB SSD and 1TB HDD
